Home made Grain fillers
Forum topic by Gene Howe posted 11-08-2010 06:18 PM 16412 views 5 times favorited 8 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
10831 posts in 3547 days
11-08-2010 06:18 PM
Topic tags/keywords: tip resource
Lots of us work with open pored wood like red oak and need some sort of grain filler. I’v found a couple home brewed ones and one commercial product I like.
Here are two home brews I’ve used.
Use 400 grit wet/dry paper. Just wipe the piece with some oil and sand. The dust will fill the pores. Add oil, if it gets too dry. Any clear oil will work. I use Watco clear. BLO would work, too.
Or, coat the wood with Watco or BLO, then sprinkle on 4F pumice. It’ll take about a teaspoon per square foot. Rub it in using a cloth (lint free). Then, wipe across the grain to remove the excess. I use burlap for both methods. Also, I like to let both methods get a bit tacky before using the burlap.
I’ve also used a product called Timbermate, Recommended by Charles Neil. Amazon or Eagle America carries it.
All above will give you a real smooth finish. The pumice turns translucent, the wood dust, of course is already matched and Timbermate has several colors. Or, you can color it yourself.
8 replies so far
View Dez's profile
Dez
1166 posts in 4196 days
#1 posted 11-08-2010 06:33 PM
Gene
Good tips, thanks for the info.
I also like the Timbermate.
-- Folly ever comes cloaked in opportunity!
View hObOmOnk's profile
hObOmOnk
1381 posts in 4247 days
#2 posted 11-08-2010 06:40 PM
I follow the classical path: pumice or Plaster of Paris.
I use pumice in a slurry either mixed with a drying oil or shellac, or water for the plaster.
I use a small rubber squeegee to apply the filler across the grain.
This is the way I was taught more than 40 years ago by a master finisher/refinisher.
-- 温故知新
View shipwright's profile
shipwright
8067 posts in 2917 days
#3 posted 11-08-2010 06:54 PM
I like the oil and sandpaper method for a very smooth finish but a problem arises when you have two contrasting woods adjacent to each other. The dark sandings end up in the light pores and to a lesser extent (visibly anyway) vice-versa. I’ve had a problem finding a truly clear grain filler, even asked at Lee Valley and they didn’t have one, but I recently found this place: https://www.woodessence.com/Default.aspx online . I ordered some aniline dyes, water-borne poly and clear grain filler from them. I’m in the process of testing them but the filler seems to be almost the same as the clear wb poly except a slightly higher solids content (35% vs 30%) and different instructions for use. Both are of course tintable with the dyes.
Gene Howe
#4 posted 11-08-2010 07:57 PM
Well Paul, masking tape works….hehe
The pumice seems to disappear, but I’ve not tried it across two contrasting woods.
shipwright
#5 posted 11-08-2010 09:04 PM
I have to admit Gene, I haven’t tried pumice. I do like and use the oil technique but try masking my last project. The stuff I bought seems to work but I will try pumice. Thanks Gene. Good topic.
Gene Howe
#6 posted 11-09-2010 01:30 AM
Let us know how that clear filler works out. Not sure I’d like working with poly as a filler. Too messy.
shipwright
#7 posted 11-09-2010 03:43 AM
When I post my current project, it will be included in the blog. Maybe two weeks.
View Jim Crockett (USN Retired)'s profile
852 posts in 3852 days
#8 posted 11-09-2010 05:36 AM
Shipwright, Crystalac makes a clear grain filler. I recently bought a quart but haven’t had a chance to try it out yet. Everything I’ve read on it says that it is water clear (guess that would depend on your water, eh?).
When I get the opportunity to try it, I’ll leave a review post.
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
