Miter Gauge malfunction
Forum topic by Walt posted 11-08-2010 04:55 PM 1234 views 0 times favorited 10 replies Add to Favorites Watch
View Walt's profile
Walt
250 posts in 3073 days
11-08-2010 04:55 PM
Topic tags/keywords: question tablesaw
I have a delta contractors saw that is 2 yrs old and recently when attempting a 45 Degree cut for a picture frame. I began to have trouble keeping the angle consistant. After rechecking for the 4th time I discovered that the handle meant for locking the gauge in place would not tighten completly. Turning it I could feel it start to tighten then go loose and just spin.
I know it is time to get a new one but I was wondering if anyone has some suggestions on how to correct this problem. The threads do not appear to be stripped. I was thinking of trying to place a small nut secured with CA gllue and see if that will correct the problem so I can finish this project while waiting for the new Incra gauge
-- Walt Wilmington Delaware, http://waltlumley@yahoo.com
10 replies so far
View richgreer's profile
richgreer
4541 posts in 3309 days
#1 posted 11-08-2010 05:06 PM
Not to discourage you, but I’ve never found a original miter gauge with a TS that was any good. Personally, I really like the Osborne OB-3. I switched to it after using an Incra for years.
3810 posts in 4256 days
#2 posted 11-08-2010 05:10 PM
Norm Abrams and I both recommend the Osborne B as well. <g>
Consider it an upgrade to your current saw regardless of the brand.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3341 days
#3 posted 11-08-2010 06:30 PM
I concur.
View MedicKen's profile
MedicKen
1615 posts in 3696 days
#4 posted 11-08-2010 06:35 PM
It sounds like the handle is stripped. Is the handle plastic? If so, you might consider drilling it out and using a heli-coil inside the handle to basically re-thread the locking handle.
View ajosephg's profile
ajosephg
1880 posts in 3795 days
#5 posted 11-08-2010 07:32 PM
Yep, suck it up and get the Osborne, you’ll never be sorry.
-- Joe
View Delta356's profile
Delta356
463 posts in 3088 days
#6 posted 11-08-2010 07:36 PM
I have the same saw as you do, but mine came with the newer virsion miter gauge. Any way’s mine has a metal handle, so I think I agree with Medicken, that the handle is stripped, I would call delta and see if you can the part.
Thanks, MIchael Frey
Portland. OR
FREY WOODWORKING INC.
View Walt's profile
Walt
#7 posted 11-09-2010 02:35 AM
Thanks for all the advice. I have not hear of the Osborne. Where can I get a look at one?
View araldite's profile
araldite
188 posts in 3638 days
#8 posted 11-09-2010 02:58 AM
I happen to like the Incra miter gauges but the Osbornes are excellent. Check out www.osbornemfg.com I think Woodcraft sells them also.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
View canadianchips's profile
canadianchips
2616 posts in 3231 days
#9 posted 11-09-2010 03:45 AM
Throw the plastic knob away and find a metal wingnut that fits your threads !
View Walt's profile
Walt
#10 posted 11-09-2010 02:50 PM
Thanks araldite
I will check it out
