| Forum topic by FaTToaD | posted 928 days ago | 3980 views | 1 time favorited | 22 replies | ![]() |
928 days ago |
Topic tags/keywords: dado freud oshlun amazon rockler question I finally decided to get myself a dado blade. Originally, I was set to get the Oshlun 8” because of the cost and great reviews. Unfortunately I missed out on the Rockler and Amazon sell a couple weeks back. However, when I went looking on Amazon this morning, the Oshlun SDS-0842 8” is ~$85. Still not terrible, but they have the Freud SD208 8” for ~$94! This may be a silly question, but is there any reason not to get the Freud? I’m assuming it is a much better set, but I wanted to know what the experts thought. Any suggestions or info would be greatly appreciated! Thanks. -- David |
22 replies so far
#1 posted 928 days ago |
I’ve no experience with the Oshlun however I’ve yet to be disappointed with any product that I’ve purchased that had the Freud name on it. |
#2 posted 928 days ago |
I own the Freud set you mention. Outstanding, and nice flat bottoms. I was fortunate enough to get one at Menards with all the shims for $60 back in January. |
#3 posted 928 days ago |
David, I have the Oshlun set and like them. If you would like to try my set first, you are welcome to. I have to agree with syenefarmer about Freud products. Rand |
#4 posted 928 days ago |
If you have a 1.5HP saw, you might consider a 6” Dado set to reduce the load on the motor. Just a thought… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#5 posted 928 days ago |
I’m planning on buying some Oshlun products soon. Just looking at the website and their offerings is pretty impressive. Probably made in asia but I have no problem with that. I’ve been involved with commercial shops for 40 years and Freud has always been middle of the road stuff, not high end, so it’s not hard to find competitive products. http://www.oshlun.com/oscillating_tool_blades.html -- Few folks really know how to maximize the potential of their tools! |
#6 posted 928 days ago |
I have a Rigid TS3650 with 1.5 HP motor, I’ve been debating for weeks now whether I should get the 6” or 8”. I plan on building a nice cross cut sled to help with making tenons, so I was a bit concerned about the depth of the 6”, does anyone know wha the max cut hieght of a 6” set is? -- David |
#7 posted 928 days ago |
What’s the max cut on a 10” saw blade? Subtract 2” and there you go. -- Few folks really know how to maximize the potential of their tools! |
#8 posted 928 days ago |
I too have the Ridgid TS3650 and the 1.5 HP motor. I know there are those that say that the motor is a little underpowered to handle the 8” set. From personal experiece I do not find that to be true. I have the 8” Freud set and have had NO issues at all. Keep in mind that most of what I have done has been case work, so cutting into just plywood. I did do one project that required 1/2” wide 1/4” deep dados into rock maple, but stilll did not have an issue. The saw is just wired to 110VAC as I do not have a 220VAC line run to my garage/shop, so the underpower issue that some people warn about does not apply to the TS3650 IMHO. So all that being said, go with the Freud, you will not be disappointed!! |
#9 posted 928 days ago |
Freud is a great brand and you won’t go wrong by it. The big difference between the two sets is that the Oshlun dado set has a chipper designed to work with undersized plywood. In order to get the same thing with a Freud dado, you’d have to lay out a lot more money. |
#10 posted 928 days ago |
I have decided on 8 for those reasons of depth. Now, which one?? ;-)) -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#11 posted 928 days ago |
JBFromMN That’s good to hear, I have my TS3650 wired at 110VAC as well. I would mostly use for the dado would be case work and box joints, maybe some tenons some day when I get the courage to try them. botanist So the Freud doesn’t have chippers for undersize plwyood? That’s kind of disappointing, but good to know. -- David |
#12 posted 928 days ago |
Botanist, the $94 set from Freud is most likely the same set I have. About the same I paid for it. It comes with shims for doing all of the odd sizes of plywood. No extra outlay of money is required. |
#13 posted 928 days ago |
I have the Freud Super Dado 8” I use it on a 1 3/4 HP motor with no difficulty. I cut 3/4 wide 3/4+ deep box joints the other day clean as a whistle. I highly recommend it. -- chas -- looking for Serta sponsorship to go Pro... |
#14 posted 928 days ago |
Let me give you a different perspective. Do you really need an 8” dada set? I find that in actual practice, every dado I cut can be handled well with a 6” dado set. It’s quite rare to need to the extra depth an 8” gives you. When that happens (very rarely) I use a conventional saw blade and make a lot of passes (then clean up the bottom with a chisel). A switch to a 6” will cost you less and/or allow you to step up to a higher quality set. Personally, I use a Freud SD 606. It is the 6 inch version of their dial-a-width product. I think it is great but it is not for everyone. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#15 posted 928 days ago |
Freud is a popular brand, and they have some very nice blades/cutters. The Freud dado you mentioned (SD206/208, DD206/208) is their entry level set, and it features only 2 teeth per chipper and 12 teeth per outside cutter. Freud’s SD500 series has more teeth, cuts cleaner, and is more expensive. That doesn’t mean the SD20 series doesn’t cut clean enough for most applications. It’s well made, and works well, but does not cut as cleanly as some of the better sets with more teeth. Most users of the Oshlun are satisfied….hard to say which cuts better without putting them side by side. In the $100 range, I’d opt for the Delta/DeWalt 7670 with 4T chippers and 24T cutters. It’s a similar design as the Forrest Dado King…not quite that level of excellence, but it cuts cleaner than the Freud SD200, has a great carrying case, nice shim stock, and is a heck of a bargain from Grizzly for $89 plus s/h. I’lol 2nd the Infinity Dadonator as the best I’ve used if you’re willing to spend in the $180 range. FWIW, I’ve never had issue spinning an 8” dado set even with my little Delta 36-600. My GI 50-185 and Cman 22124 spun the 8” SD208 with ease. There tends to be more choices with an 8” set, which gives you more opportunity for a great deal. If the price is close, I’d definitely go with 8”, but if there are significant savings, go with a 6”. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15809 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
