For Sale - Rockwell/Delta 11-100 Drill Press
Forum topic by brianinpa posted 11-08-2010 04:16 AM 10792 views 0 times favorited 5 replies Add to Favorites Watch
View brianinpa's profile
brianinpa
1812 posts in 3717 days
11-08-2010 04:16 AM
Topic tags/keywords: rockwelldelta drill press
I recently bought a Vintage Craftsman (Companion) drill press so now I have two. One of them has to go, so this is the one.
Nothing wrong with it except I don’t like the color, but that is just my taste. I have it listed on Craigslist for $100.00 but I will sell it to a LJ for $65.00. Sorry to say that because of the size and the weight, you will need to pick it up.
5 replies so far
View JuniorJoiner's profile
JuniorJoiner
486 posts in 3434 days
#1 posted 11-08-2010 04:36 AM
too bad you are so far, these vintage drill press are great machines, way better than most new.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
brianinpa
#2 posted 11-08-2010 04:47 AM
Been used for metal and wood, and I have never been able to stop the motor. The DP that I picked up recently is even older, but I want the other becasue it fits in better with my other Craftsman tools. Just have to find a bandsaw to complete the shop.
View rolltopbox's profile
rolltopbox
71 posts in 2987 days
#3 posted 11-08-2010 05:17 PM
Unfortunately this machine uses proprietary bearings that are pricey to buy. It was the only reason I sold my 11-100 and my 220 (14”) drill press because they both use the same proprietary bearings.
-- Bruce http://www.finecraftfurniture.com
brianinpa
#4 posted 11-09-2010 12:57 AM
I can see where this might be a problem if your drill press has bad bearings, but that isn’t the case with this drill press.
View Bluepine38's profile
Bluepine38
3379 posts in 3079 days
#5 posted 11-09-2010 05:15 PM
That would fit right in with my other old Rockwell/Delta tools if you were a little closer. The proprietary
bearings rolltopbox was referring to can be gotten around by using machine bushing spacers on some
machines, the bearing has an offset collar, but regular bearings give the same bearing surface and you
just have to compensate for the offset inner race. Even if you have to buy their bearings, it is still less
expensive than replacing the drill press.
