Big Daddy or Whiteside Ultimate router bit
Forum topic by ScaryDull posted 04-27-2017 11:03 PM 2780 views 0 times favorited 7 replies Add to Favorites Watch
View ScaryDull's profile
ScaryDull
8 posts in 1378 days
04-27-2017 11:03 PM
Topic tags/keywords: router
I need a large pattern bit – and I’m looking at either the Big Daddy bit from William Ng or Whiteside’s Ultimate compression pattern bit.
The Big daddy is massive – but high speed steel from what I’ve heard – the whiteside bit is a compression (up cut and down cut) bit of solide carbide – but it’s (comparatively) smaller – cutter height 1 1/8” vs. 2”
Any thoughts or experiences?
7 replies so far
View knotscott's profile
knotscott
8080 posts in 3432 days
#1 posted 04-27-2017 11:05 PM
For cutters, I’d take good carbide over good steel any day.
View JayCee123's profile
JayCee123
200 posts in 821 days
#2 posted 04-27-2017 11:17 PM
What are you cutting … material and thickness?
Are you planning to ride the bearing along the template mounted above or below the work piece?
View waho6o9's profile
waho6o9
8242 posts in 2633 days
#3 posted 04-28-2017 12:08 AM
Big Daddy Pattern Bit!
Custom router bit made of cobalt, 1/2″ shaft, 1-1/8″ diameter, 2″ cutting length, 6 flute spiral, 3/8″ bearing, overall height is around 4-1/2″. We recommend using a router speed of 13,000 rpm with this bit. With 6 flutes, the cutters comes around very quickly. Remember to always use a blade guard. Smooth cuts every time, with or against the grain.
Combine this with our big daddy dust hood and guard.
Around 145.00
https://wnwoodworkingschool.com/shop/big-daddy-pattern-bit/
vs
http://www.carbideprocessors.com/whiteside/solid-carbide-spiral-router-bits/flush-trim-spiral-router-bits/
Around 165.00
That’s a tough call as I’ve never used a cobalt router bit and William Ng doesn’t sell lower end products.
I’d go with Whiteside as I’ve had great results with them:
View BurlyBob's profile
BurlyBob
5661 posts in 2321 days
#4 posted 04-28-2017 01:10 AM
To my way of thinking Whiteside is the only game in town.
ScaryDull
#5 posted 04-28-2017 08:02 PM
I’m primarily going to use it on hardwoods – often not thicker than 1” – but I’m hoping I can use it for wider material also – so with the whiteside bit (the one with the bearing closest to the router) I hope you can take on thicker material with a second pass.
I think the larger Big Daddy (nice name) has it advantages in a wider diameter and ability to taker thicker material in one pass. Whereas the Whiteside is solide carbide and a compression bit.
I’ve had really good results with Whiteside so far, so I’m probably leaning that way.
View ClammyBallz's profile
ClammyBallz
440 posts in 1192 days
#6 posted 04-28-2017 08:40 PM
FYI, best pricing on Whiteside bits is on this site. I’ve ordered twice and my stuff showed up the next day.
https://woodworkersworld.net/whiteside-ultimate-up-down-spiral-plunge-pattern-router-bit-udp9112.html
ScaryDull
#7 posted 04-29-2017 08:20 PM
Thanks for the help.
