So what is a good finish and process for finishing teak for a boat? This will be for a platform on the back of the boat to get in and out of the water then into the boat. I have done a lot of reading on boat forums about a thin coat of epoxy then coats of spar finish. Anyone have experience on the subject please leave some advise and comments. Thanks for reading and offering advise if you do.
It largely depends on how much work you want to do over your ownership of the boat. Any bright finish will require a good bit of upkeep. If I were going to do a swim grid I would not go epoxy / varnish although that will work in "dryer areas". I would go with Cetol Marine from Sikkens. https://www.jamestowndistributors.com/userportal/show_product.do?pid=167
That is if I were going to finish it bright which I likely would not. Teak goes a very nice silver grey if left on its own and is virtually maintenance free. That would mean a lot more time enjoying the boat and a lot less refinishing.
Thanks shipwright it's for a buddies boat and he wants it to be shiny and look more like a mahogany. About 1/16 all the way around the wood was dry rotted and the previous owner just painted over it so I have all the pieces ready to put back together now after planing.
As a former boat owner (times five, but I'm clean and sober now!), I agree with Shipwright's recommendation. Cetol is the way to go. Whether you go silver or not is up to you and your buddy. But Cetol will give you a longlasting finish that stands up to UV and other weather damage.
Just use a good Teak Cleaner and then Teak Oil. Anything else is just asking for trouble and extensive labor down teh road. Cetol will look like river mud with in 6 months.
My uncle's Mastercraft sees at least 200 hours per year and gets a light cleaning in the middle of the summer followed by teak oil. In the winter (if it comes off the in water lift) it gets a more thorough cleaning with a little light sanding when needed followed by teak oil. This has been the process for 7 boats over the past 30 years or so; quick, easy & effective.
Any Polyester underneath a urethane will heat too much in the sun and cause lift of the poly. So I recommend either or. Teak oil is the best in my opinion. Saw a lot of Teak Junks getting the teak oil treatment when I was a kid in Hong Kong and they were 40plus yrs old.
Another cetol user here. I sanded down to bare wood and put 4 coats on a few years ago and a light sanding a new coat in the spring after that and the teak looks great.
You must have used the wrong Cetol. They have a wide range of products. I've had Cetol "marine" on my decks for twelve years. Cetol "deck" is for sundecks and I think has more pigment. I have seen it look muddy after too many coats.
At last check, teak oil is just boiled linseed oil, resin and thinner. It has no UV protection and isn't really an exterior finish. Of course, if yours is from squeezed teak trees…..
So he wants to go the teak oil route. I read that exterior teak oil does have uv blockers in it so we will see how it does and if it doesn't do well I can always use the cetol.
Well I think it will give him a idea of what the wood will look like sealed then he can decide if he wants it stained or cleared and it will be less work for me in the long run by starting with the oil.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
