Box/drawer clamping - has anyone experienced this?
Forum topic by JJohnston posted 11-08-2010 12:16 AM 4496 views 0 times favorited 6 replies Add to Favorites Watch
View JJohnston's profile
JJohnston
1622 posts in 3260 days
11-08-2010 12:16 AM
I’m not terribly experienced in building boxes and drawers, and I observed something unexpected today. Anybody else notice this?
I was gluing up drawer boxes, 1/2” baltic birch, about 8.5”x24”x19” outside dimension. I’m using a lock rabbet corner joint (see picture). On the first 2 of 4 I put the clamps on as shown in the upper picture; no particular reason, just that I would put the clamps on the first side, then spin it around, and put the clamps on the second side the same way. These were not square as they went together, and I was having to use a squaring clamp. They were both out-of-square the same way: the long diagonal was between the moveable jaws.
On the next 2, I was using much longer clamps, and I decided to have all the tails pointing the same way to make them easier to handle (as shown in the lower drawing). When clamped up this way, they were square. I went back to the first 2 and flipped the clamps on one side, and they became square without a squaring clamp.
Am I the last one to know about this, or have I discovered something new?
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View nailbanger2's profile
nailbanger2
1041 posts in 3112 days
#1 posted 11-08-2010 12:36 AM
I’m not lucky enough to have Bessey K body clamps, yet, but I’ll be watching this thread closely.
-- Wish I were Norm's Nephew
View crank49's profile
crank49
4030 posts in 2939 days
#2 posted 11-08-2010 01:01 AM
That’s what I would expect with my cabinet clamps used the way you showed. I don’t have Bessey but have a few Jorgensen Cabinet Masters. That’s the way they work. The way you turned them in the second view, if one clamp has a slight skew to it, the opposite clamp would offset the skew and cancel it out.
View traupmann's profile
traupmann
124 posts in 2755 days
#3 posted 11-08-2010 01:18 AM
Probably neither the last to know or the discoverer; I have noticed that the Bessey clamps at the clamp end do angle an they tighten. Your description is perfect. I know of no clamp that doesn’t have some inherent problem similar to this. Some years back one of the woodworking mags gave the Rockler clamps the squarest award, but mine hang while I use the Bessey.
I would guess this is one of those ‘learning’ moments. Learning to use our tools correctly and precisely is a long richly rewarding experience, wouldn’t you say?
-- chas -- looking for Serta sponsorship to go Pro...
View shipwright's profile
shipwright
7967 posts in 2766 days
#4 posted 11-08-2010 01:35 AM
I’ve never noticed it but I always set both clamps the same way so I can stand the assembly out of the way on those nice flat Bessy toes.
View jusfine's profile
jusfine
2422 posts in 2894 days
#5 posted 11-08-2010 01:51 AM
I have used Bessey clamps for many years, have about 60 or so of the K clamps, and have never noticed what you describe.
Thinking about it, I do as you have noted in your second photo, and as Paul says, clamping with tails in one direction so I can stand them out of the way to dry.
Interesting question, I will try it the first way as I am working on some drawers this week.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
JJohnston
#6 posted 11-08-2010 02:45 AM
Great – I’ll look forward to your results.
