Split Spindle on a Spring Pole Lathe
« back to Woodturning forum
Forum topic by Ron Aylor posted 04-27-2017 07:58 PM 1047 views 0 times favorited 8 replies Add to Favorites Watch
View Ron Aylor's profile
Ron Aylor
2649 posts in 822 days
04-27-2017 07:58 PM
Topic tags/keywords: spring pole lathe split spinle question
My next Prie Dieu will feature a a split spindle. I’m aware of the brown paper glue-up to achieve this, but I’m concerned about stressing the glue joint with my spring pole lathe. I do not have mandrels, just metal centers from a weaving shuttle.
I’ve considered driving cut nails from opposite directions at the ends of the turning blank, or even a leather strap of sorts to keep the blank from flying apart. What say ye? Any experience with a split spindle on a spring pole lathe?
Thanks in advance for any and all comments.
8 replies so far
View REO's profile
REO
929 posts in 2248 days
#1 posted 04-27-2017 09:07 PM
run the blank long and short sheet the paper. cut the end back to length when done then split. I dont run a spring pole and use cup centers typically though.
View JADobson's profile (online now)
JADobson
1242 posts in 2285 days
#2 posted 04-27-2017 09:08 PM
I think I saw someone wrapping a few turns of packing tape around an inside out turned ornament. If I remember right they skipped the glue altogether and just relied on the packing tape. That was very small scale though. I bet between the glue and the tape you’d be fine. But I’ve never done it so it’s purely conjecture.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View Woodknack's profile
Woodknack
12399 posts in 2555 days
#3 posted 04-27-2017 11:50 PM
Why not do a test before completely dismissing the idea
Ron Aylor
#4 posted 04-28-2017 01:00 PM
Thanks, guys! I like the packing tape approach. This would hold as well as the cut nails, I guess. I do, however, think I’ll need to do the glue-up. The spring pole lathe only allows cuts on the down stroke and offers not a lot of torque. A misplaced tool has caused this thing to stop dead in its tracks or even dislodge the work-piece, sending it crashing into the wall. Without the glue I’m afraid the blank might crack or at least have a chunk of wood go missing. Guess I’ll glue things up with brown paper, bind the “extended” ends, say a little prayer, and see what happens. Thanks, again!
View Planeman40's profile
Planeman40
1273 posts in 2935 days
#5 posted 04-28-2017 01:24 PM
You might also want to consider using automotive hose clamps.
http://www.hcl-clamping.com/Worm-Gear-Hose-Clamp-US-Style-P14
Ron Aylor
#6 posted 04-28-2017 01:25 PM
- Planeman40
Thanks, Rufus … I’ll look into that as well!
Ron Aylor
#7 posted 08-22-2017 12:04 PM
UPDATE … Turning a split spindle on the spring pole lathe was rather uneventful and required no special preparation. I simply glued the two halves together with brown craft paper in between. I did do as REO suggested and ”short sheet”  the paper about 1/2” from either end. This proved sufficient in keeping the blank from splitting on the lathe. Check out my blog to see the results.
View Jack Lewis's profile
Jack Lewis
335 posts in 1253 days
#8 posted 08-22-2017 01:18 PM
Spring pole lathe! I gotta get one of those.
Signed; a tool junkie
-- "PLUMBER'S BUTT! Get over it, everybody has one"
