Drill press
Forum topic by Tom posted 04-27-2017 07:00 PM 655 views 0 times favorited 7 replies Add to Favorites Watch
View Tom's profile
Tom
178 posts in 1207 days
04-27-2017 07:00 PM
I have a HF benchtop drill press; had it for years and it cost me about $50 new. It’s never been great but was good enough for my projects….but now I’m wanting a bit more precision and think this needs to be replaced. When it’s running the tip of the drill bit wobbles just a bit, with a forstner bit it’s fine but regular bits can drift or cut at an angle into my project. Any recommendations on a better (but not expensive) press? I’ve shopped my local CL for used and people are asking $50 – $150 for small presses like mine and I’m not sure which is good. Any opinions on a brand to shop for? I’m definitely not getting any HF/Ryobi products and am willing to pay for a quality tool.
7 replies so far
View dbw's profile
dbw
207 posts in 1784 days
#1 posted 04-29-2017 09:13 PM
I bought the Porter Cable floor standing model Lowe’s sells. I paid +- $300. It’s a good value for the $. The wobble is approximately .008 TIR at the tip of the chuck.
-- measure 3 times, cut once
View HorizontalMike's profile
HorizontalMike
7770 posts in 3061 days
#2 posted 04-29-2017 09:45 PM
FWIW, I bought and used my Delta 8in DP for over 21yr BEFORE I finally wised up and went whole hog with a 20in Grizzly DP (roughly $800 delivered). Geez… you wouldn’t believe how many “jigs” I made to get by with less before upgrading! Not kidding!
OK, sure this costs more up front, but what I have really discovered is how much I can use a larger DP on every day projects… IMO, scaling up over time is over-rated. Buy as BIG as you can NOW. Anything less is wasted $$$$ unless you are on your death bed and in your 80-90s. I have finally gotten tired of just “gettin’ by…”. At some point, you too may reach that point. Life is now good for me, now that I made that mental leap. Just sayin’
HorizontalMike
#3 posted 04-30-2017 06:37 PM
What I forgot to mention earlier is that with the larger DPs, you can get SLOWER speeds for when using larger forstner bits and hole saw bits. THIS is a very important thing to consider. I burnt up so many bits with my little 2-speed 8in DP,...geez! }8-(
My 20in DP has…Number of speeds: 12 (210, 310, 400, 440, 630, 670, 1260, 1430, 1650, 2050, 2350, 3300 RPM)
View Carloz's profile
Carloz
1147 posts in 739 days
#4 posted 04-30-2017 07:06 PM
, with a forstner bit it s fine but regular bits can drift or cut at an angle into my project.
- Tom
My guess is your regular bits are not straight enough.
View Tom's profile
Tom
#5 posted 04-30-2017 11:34 PM
.008 wobble would be great…mine has a .375 wobble. With a forstner bit it stops once in the work but whit a normal bit it’s a mess. I don’t really have room for another floor tool so I’d be looking into a benchtop model. I figure a 12” would be a good size. Just have to save some $$ for one…and keep checking CL to see if something comes up.
Carloz
#6 posted 05-01-2017 01:45 AM
A general misconception. With a bench top drill press you have two choises:
1. Leave it on the bench, which will make the bench unusable for most other tasks.
2. Make a dedicated small bench, which will take more space than a floor drill press.
View Tom's profile
Tom
#7 posted 05-01-2017 02:09 AM
My bench is 3 feet deep and 8 feet long. Space on it isn’t an issue. Got it from a former employer that was downsizing and it was being tossed out. Even has a small shelf underneath that stores…We’ll I’m not sure what is there.
