Long-term storage for equipment with cast iron tables
Forum topic by GregD posted 04-27-2017 06:42 PM 1976 views 0 times favorited 10 replies Add to Favorites Watch
View GregD's profile
GregD
788 posts in 3284 days
04-27-2017 06:42 PM
Topic tags/keywords: question tablesaw jointer drill press bandsaw
Are there any recommendations for long term (1 or 2 years) storage of equipment with cast iron tables?
Due to changes in my living situation I expect my table saw, jointer, band saw, and drill press will be unused for 1 to 2 years. They will be in an unheated garage or shed in western Montana.
I was thinking of spraying the tops down with dry lube and covering them with wax paper while the lube was still wet. And then covering them with old bath towels and canvas drop cloths. When I’m ready to put them back in service I’m expecting to clean them up with Scotch Brite and WD-40 or some other cast iron cleaner and then apply a cast iron top lube product.
-- Greg D.
10 replies so far
View Loren's profile
10477 posts in 3796 days
#1 posted 04-27-2017 07:06 PM
I’ve had good results in my dry climate using
HTC machine covers.
View diverlloyd's profile
diverlloyd
3121 posts in 2005 days
#2 posted 04-27-2017 08:09 PM
You could use museum wax I have also thought about using the vinyl wrap that is for cars.
View DrDirt's profile
DrDirt
4464 posts in 3890 days
#3 posted 04-27-2017 08:21 PM
At least it is a dry climate….
Might go for the tables the way it was shipped with the heavy/greasy Cosmoline that protected it at sea and in storage for months.
You might ask Saw Stop what they recommend.(or have applied at the factory making the equipment)
http://www.cosmolinedirect.com/mil-spec-grease-mil-c-11796c-class-3/ MIL-SPEC Grease (MIL-C-11796C, Class 3) is a medium grade grease/corrosion preventative compound that can prevent rust and corrosion for years, even in the harshest of environments. MIL-C-11796C, Class 3 is commonly used to protect/preserve equipment, machinery, firearms, and any other metal surface when put in long-term storage or while in transit (overseas, road, marine, etc.).
View MrUnix's profile
MrUnix
6948 posts in 2347 days
#4 posted 04-27-2017 08:49 PM
This question pops up every couple of months. If you do a search on this site for ‘long term storage’, you will find a lot of information and discussion on the subject:
Long Term Storage
View Dark_Lightning's profile
Dark_Lightning
3261 posts in 3257 days
#5 posted 05-01-2017 02:35 AM
Cosmoline. I bought a Record lathe that was 22 years old and still had the Cosmoline on it. Just a little light rust on the parts that didn’t have a thick coat. Or, just lay on a coat of oil based paint. It’ll be tough to get off, but that means that the rust won’t be able to get at it.
-- Random Orbital Nailer
View EricTwice's profile
EricTwice
237 posts in 681 days
#6 posted 05-01-2017 02:41 AM
Cosmoline if you can get your hands on it. You need something to keep the moisture out. a couple of heavy coats of linseed oil, but like your dry lube and wax paper it might be difficult to get off after a couple of years.
-- nice recovery, They should pay extra for that mistake, Eric E.
View Carloz's profile
Carloz
1147 posts in 740 days
#7 posted 05-01-2017 03:01 AM
.... And then covering them with old bath towels and canvas drop cloths. ...
- GregD
This is the worst idea ever. Towels will collect moisture and pass it on to the iron. Some tarp from harbor freight will make much better job.
Carloz
#8 posted 05-01-2017 03:07 AM
Once I looked at a table saw that spent 10 years in an climate uncontrolled storage. It had no protection whatsoever the owner even did not put wax on it. It got some thin film of patina but zero rust. This was however in Southern California, fairly close to the water.
View Woodknack's profile
Woodknack
12369 posts in 2528 days
#9 posted 05-01-2017 03:37 AM
My personal experience is that towels, blankets, or sheets on cast iron will cause rust because as Carloz says, they hold moisture. I wouldn’t recommend tarps either because they can trap condensation. The only time I would use a covering is is if moisture will be dripping onto the table. And if I were using a covering I would put a frame over the table so it wasn’t in contact and air could get underneath.
One option is clean and degrease then put on a coat of polyurethane. Several people have done that with excellent results. Another is wd40 or some type of grease or heavy wax.
View rwe2156's profile
rwe2156
3094 posts in 1629 days
#10 posted 05-01-2017 03:49 PM
I would coat with WD40 to remove surface humidity, slather on axle grease and put a piece of 6mil plastic on top of that.
Do NOT use wax or you’ll have a real mess in a couple years (how do I know that?)
