Advice on resawing with a Rikon 14" Deluxe Bandsaw
Forum topic by harrywho posted 928 days ago 1664 views 0 times favorited 7 replies Add to Favorites Watch
View harrywho's profile (online now)
harrywho
95 posts in 1403 days
928 days ago
I’ve been wanting a Rikon 14” Deluxe Bandsaw for quite awhile now and Woodcraft has them on sale this month so I’m considering taking the plunge. Before I do I would like some advice from you guys. I know the saw has received rave reviews on Lumberjocks but I have also read that the factory fence isn’t that great. My question is about resawing. I plan on doing quite a bit of it with the saw. Is the fence adequate for fine resawing, say 1/8”?
If it isn’t is there an after market fence that you would recommend, I see the Kreg requires major modification which I don’t want to do.
Of course I want to hear that the supplied fence works great but if it won’t I guess I would like to know now rather than after I buy it.
Any advice greatly appreciated.
-- Harry, Indiana
7 replies so far
View NBeener's profile
NBeener
4856 posts in 1344 days
#1 posted 928 days ago
I, too, have heard great things about the … I think … 10-325.
You can pretty easily make your own resaw fence, from plans like this one
Others have posted plans/ideas for DIY resaw fences, on the Net, too.
I’ve also heard good things about the MagSwitch (note: my brother works for them) resaw fence, but haven’t personally tried one … yet ;-)
-- -- Neil
View DonH's profile
DonH
482 posts in 988 days
#2 posted 928 days ago
Hi harrywho
I wouldnt worry about the fence as it is very easy to make one if the supplied fence is inadequate. There are a number of aftermarket fences available – I use the Kreg fence on one of my bandsaws and a shop made one on the other – both work just as well.
-- DonH Orleans Ontario
harrywho
#3 posted 927 days ago
Thanks guys, sounds like it’s a non-issue. If the fence won’t do what I want I will make one or get the MagSwitch.
I will order the saw tomorrow!
Harry
-- Harry, Indiana
View Ryan Brown's profile
Ryan Brown
72 posts in 1360 days
#4 posted 927 days ago
If you plan on resawing, you really need to get a good blade too. The guys at Woodcraft will tell you that it comes with a decent blade. While it might be decent, it can’t compare to a Wood Slicer blade from Highland Woodworking.
Review, feedback and links here!
You’ll love that saw. Oh, you might as well order the 111” blade now so you you’ll have it when you get the saw. Just make sure you try making some cuts with the stock blade first, so you can truly appreciate the awesomeness of the Wood Slicer.
-- If you can't fix it with a hammer, you have an electrical problem. Roanoke, VA
harrywho
#5 posted 927 days ago
Thanks Ryan, I am picking up my saw tomorrow and am going to order a Wood Slicer. One question, are you happy with the 1/2” blade or do you think the 3/4” would be better?
Really appreciate your advice and review.
Harry
-- Harry, Indiana
Ryan Brown
#6 posted 927 days ago
The 1/2” blade works great. I haven’t had any issues with it wandering once I set up my fence for the drift angle. I’ve had excellent results and I can’t say enough good about that blade. In fact, after re-sawing, I typically only need to take off about 1/32” in the planer to get a smooth surface. The slower the feed rate, the smoother the finished cut will be.
I actually use that blade for nearly everything, because it’s good for nearly everything. If anything I need to get a 1/4” blade so I can make tighter turns with it.
View DonH's profile
DonH
#7 posted 927 days ago
I have used both the 1/2 inch and 3/4 inch woodslicer blades and prefer the 1/2 inch. It cuts smoother and has a narrower kerf. This is my regular day to day blade on my 16 inch saw.
