Deck boards with ink stamps
Forum topic by MHW posted 04-27-2017 03:08 PM 1244 views 0 times favorited 9 replies Add to Favorites Watch
View MHW's profile
MHW
8 posts in 458 days
04-27-2017 03:08 PM
Topic tags/keywords: deck decking wood pressure treated question
We purchased Premium Pressure Treated Weathershield boards. The boards have ink stamps on their surface. What do I do to remove the ink before I stain or seal?
9 replies so far
View JCamp's profile (online now)
JCamp
709 posts in 601 days
#1 posted 04-27-2017 03:22 PM
MY wife’s uncle always use to sand them out. I flip them over An just use the other side
-- Whatsoever thy hand findeth to do, do it with all thy might
View gargey's profile
gargey
1007 posts in 826 days
#2 posted 04-27-2017 03:42 PM
Just get teak instead
View jerryminer's profile
jerryminer
935 posts in 1492 days
#3 posted 04-27-2017 06:23 PM
Like JCamp said, you have two choices:
1. Sand off the label
2. Turn the board over
JCamp
#4 posted 04-27-2017 06:51 PM
He was the only person I hav ever seen sand them out. I think he more so just liked looking busy but he seemed to get a lot of odd job so buikding decks even though he was SLOW. All I’ve ever done was put them face down except where they were used as railing
View DirtyMike's profile
DirtyMike
637 posts in 952 days
#5 posted 04-27-2017 06:56 PM
Dont let a stamp dictate which side of the board is up. That cheap decking is going to move,shink and cup. cup side up makes for a bad deck in 2 years.
View MHW's profile
MHW
8 posts in 458 days
#6 posted 04-27-2017 07:03 PM
What’s is “cup side up”?
View tomsteve's profile
tomsteve
791 posts in 1270 days
#7 posted 04-27-2017 08:04 PM
basically its the way the lumber will “cup” as it dries out.
im not sure if youre aware of it, but its usually a good practice to give the deck some time to dry out( with pressure treated wood) for a while before applying stain/sealer. just my opinion, but in climates such as I have here in west metro Detroit,mi, I say if the deck is constructed in april or may, then somewhere around august is good. but would still like to wait a year.
one other thing: if sanded, it could make that area a different color if stained/sealed right after. if im not mistaken its a water based ink used for the stamping so something like dawn dish soap,water, and a scrub brush should take it off. but it might just require time.
View JayCee123's profile
JayCee123
200 posts in 815 days
#8 posted 04-27-2017 09:51 PM
Agree with tomsteve and DirtyMike the bark side should be placed down against the framing.
PT lumber is usually saturated with water when its laid. You should wait 3 – 6 months before applying a stain or finish.
The ink stamp can be sanded off. The normal wear and tear the deck will receive over the next 3 – 6 months will allow the sanded spot to receive the stain or sealer uniformly.
By the way, don’t add any drainage gap between boards as their laid. As the moisture leaves the lumber over the next few months the boards will shrink across their width and create the gap. If you lay the boards with a gap, you’ll end up with a wide unsightly gap between the boards.
View bigblockyeti's profile
bigblockyeti
5155 posts in 1771 days
#9 posted 04-28-2017 06:44 PM
You definitely want the bark down, this bench is of red oak I milled and didn’t stack. It cupped so severely that I used it as a design element.
