Cutting Board Wood Question
« back to Woodcarving forum
Forum topic by Jackcarter0714 posted 04-27-2017 03:57 AM 961 views 0 times favorited 7 replies Add to Favorites Watch
View Jackcarter0714's profile
Jackcarter0714
20 posts in 546 days
04-27-2017 03:57 AM
Hey there fellas. I’m a bit new to wood working and carving. I have a question regarding what type of piece of wood I should use, and more importantly where to get it. I’m planning on setting out to carve a cutting board. A fairly big but thin one, I have my reasons. About 2’x2’ and around a 1/2” thick. I have all of the plans worked out. But I cannot figure out which cut of wood I would need or where to get it. I figured I would need just a big ole slab to start with, and work it down. But I cannot think of any piece of wood sold like that. Sure, the hardware stores will carry inch thick, fairly large boards, but I definitely do not trust that wood.
Is there something I am missing here? What have you fellas used in the past for cutting boards? Any help will be greatly appreciated and thanked.
7 replies so far
View jerryminer's profile
jerryminer
944 posts in 1585 days
#1 posted 04-27-2017 08:28 AM
A single board, 24” wide and 1/2” thick is going to cup. It won’t work well for a cutting board (and will be hard to find).
The most stable wood (of any species) will be “quarter-sawn.” A cutting board is typically made by gluing together a series of smaller boards to achieve the desired width. Thicker is also better for stability—staying flat over time.
You’ll need to be able to prep the wood for gluing, clamp, and flatten afterwards.
You need to find a source for hardwood (search “hardwoods” for your area or talk to a local cabinet shop for small amounts)
Hard maple is traditional for cutting boards, but a lot of species will work well (birch, beech, cherry, ....)
View LittleShaver's profile
LittleShaver
397 posts in 763 days
#2 posted 04-27-2017 01:17 PM
Woods that are good for cutting boards are not friendly to carving. Even if you glue up strips to get to 24” wide, I think you will still have problems keeping the board flat with only 1/2 thickness.
-- Sawdust Maker
View ArtMann's profile
ArtMann
1081 posts in 960 days
#3 posted 04-27-2017 03:16 PM
Can the design you wish to build be installed into a frame? Like others have stated, it will be practically impossible to make a board like you describe that won’t cup or twist without some kind of stiffening.
Jackcarter0714
#4 posted 04-27-2017 11:08 PM
Thank you all, lads. I’ve learned much more than I thought I would from these responses. Out of necessity, I will change and redesign my project. I hope to get rolling on it in the next few weeks. I will definitely update with all of my progress.
View Ripper70's profile
Ripper70
1131 posts in 1052 days
#5 posted 04-27-2017 11:39 PM
You can learn allot from watching this guy make his boards. You’ll be blown away too!
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View MT_Stringer's profile
MT_Stringer
3173 posts in 3375 days
#6 posted 04-28-2017 12:53 AM
+ what everyone else has said.
I suggest that you pick another project to practice on. I see questions like yours asked a lot by folks new to woodworking. They usually want to make/build something that will most likely, end in disaster.
I am not sure what you mean by “carve” a cutting board. Can you explain further. Pictures would help.
My boards are simple but they do require gluing narrow strips together, then planing them flat on both sides. For the bigger ones, I cut finger grooves and/or juice grooves using a router and a cove bit.
Here are a few samples of my boards from the past.
Good luck.
Mike
Glue up for four boards
Jackcarter0714
#7 posted 04-29-2017 02:55 PM
Good luck.
Mike
- MT_Stringer
Hello there Mike. When I say “carve” I more broadly mean using only hand tools. I’m experienced with my tools in rough carpentry, but never in this kind of fine woodworking. Like I said, I’ll have to come back to the drawing board on this.
