Using CA glue to inlay " larger" areas
Forum topic by proudmary posted 04-27-2017 03:56 AM 981 views 0 times favorited 3 replies Add to Favorites Watch
View proudmary's profile
proudmary
2 posts in 297 days
04-27-2017 03:56 AM
Topic tags/keywords: question inlay metal powder inlay in wood burnishing inlay inlay adhesives
Hi! I’m brand new to this forum. Here’s my first question! I need to inlay brass powder into an area about 2-1/2” X 1” . I’m using CA glue. What’s the best way to get a uniform finish considering how fast CA dries? I I’m inlaying a flat surface. And, I need the inlay to adhere to both wood and copper metal. The brass powder I have has the consistency of flour. I’m doing test runs on scrap. I found epoxy just looks muddy and I can’t get it to burnish as good as CA. I’ve been applying a small amount of CA glue into void and let it dry before I put powder in because it seems to work best. But, when trying to do larger areas, I’m getting pits and fisheyes. What am I doing wrong? And, how do I fix pits and fisheyes if they do happen on final piece? Or, am I doing something wrong using epoxy? Am I not burnishing it properly? I use a piece of brass wire folded for burnishing. HELP!
3 replies so far
View papadan's profile
papadan
3584 posts in 3270 days
#1 posted 04-27-2017 05:21 AM
1” X 2 1/2” but how deep? I just fill the void and then add the C A. It will soak in until it is saturated. C A Does not dry that fast when not placed between surfaces.
proudmary
2 posts in 297 days
#2 posted 04-27-2017 06:29 AM
Thanks papadan! It’s about 1/16” – 1/8” deep. I must be doing something wrong if I’m getting pits and fisheyes then. I’m going to try a few more test runs to see if can figure out why its happening. Too deep maybe? But, I welcome advice!
View Dave Polaschek's profile
Dave Polaschek
1524 posts in 484 days
#3 posted 04-27-2017 10:14 AM
For 1/8” deep I would probably need two passes. Fill it most of the way with the powder then saturate with CA, but I would expect to need to come back for a second “finish coat” to fill minor imperfections, just because I never seem to get things quite right on the first try.
When I’m using CA and sawdust as wood filler, I intentionally overfill on the finish pass, then plane it smooth afterwards to get a good surface. It’s been easier to do that than to try and build it up for me, but I don’t know if I would do that with a metal powder. Probably would try it on a small piece and see how it went.
-- Dave - Minneapolis
