Hands are bleeding
« back to Hand Tools forum
Forum topic by rolandstronghammer posted 04-27-2017 01:46 AM 626 views 0 times favorited 11 replies Add to Favorites Watch
View rolandstronghammer's profile
49 posts in 795 days
04-27-2017 01:46 AM
I swear I’ve been trying to flatten the iron for my spokesshave for a straight hour now. The upper left hand corner is hanging on for dear life. My finger tips are bleeding.
11 replies so far
#1 posted 04-27-2017 02:04 AM
Done. Finally. Time to test.
View BlasterStumps's profile
545 posts in 372 days
#2 posted 04-27-2017 02:29 AM
Nice work. looks good.
I can sympathise for sure. I spent about an hour flattening and polishing the sides of a card scraper that I had made out of a fairly thin piece of saw blade. I worked until my fingers were sore and it still looked like I had a long ways to go. I decided to switch over to sand paper to get it flat then switched back to the diamond stones to finish. It still took quite a while. So yes, I can fee your pain but you will be rewarded with a tool that works like it should. By the way, I have one of those blades like yours but I busted it in half messing with it. I learned a lesson there. Congrats on getting yours in fine shape.
View builtinbkyn's profile (online now)
2045 posts in 873 days
#3 posted 04-27-2017 02:38 AM
Next time you can try using some double-sided tap and bond the iron to a solid piece of hardwood. It will give you something to hold on to ;)
-- Bill, Yo! Brooklyn & Steel City :)
View waho6o9's profile (online now)
8130 posts in 2509 days
#4 posted 04-27-2017 02:53 AM
I use magnets embedded in hardwood as my finger tips used to bleed as well.
Double sided tape is a good idea too.
View DrDirt's profile
4421 posts in 3675 days
#5 posted 04-27-2017 03:27 AM
Good thing is that is usually an “only needed once..EVER” operation.
View WhoMe's profile
1564 posts in 3176 days
#6 posted 04-27-2017 03:48 AM
Can you go a grit or two coarser and can you wear some type of glove.
I have had many a blade like that. Some of which I have has success with and some, not so much. I start with a belt sander belt glued to a piece of flat granite and try to use the palm of my hand with a glove on to get it as flat as possible before moving to finer grits to remove sanding scratches. It takes a while sometimes .
Never mind, I’m a little late. Had the reply done but forgot to hit send…
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
View Woodknack's profile (online now)
11301 posts in 2312 days
#7 posted 04-27-2017 04:54 AM
It shouldn’t take more than a few minutes to flatten a blade that size. Start with 80 grit until flat then polish as desired.
-- Rick M,
View Rrrandy's profile
212 posts in 411 days
#8 posted 04-27-2017 05:01 AM
The blood must be on your other hand…
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
View HokieKen's profile
4660 posts in 1071 days
#9 posted 04-27-2017 11:19 AM
Based on the reflection in that first pic, I’d say you started with an abrasive that was way too fine. I usually start with 220 and drop down until I get it right. Should be 20 minutes max to flatten a plane iron. Less than that for a spokeshave.
FWIW, I’m not being critical, just offering some hard-earned advice ;-P The important thing is that you got there!
-- Kenny, SW VA, Go Hokies!!!
View Mikesawdust's profile
325 posts in 2971 days
#10 posted 04-28-2017 07:30 AM
Just an idea, but does a spoke shave need to be flattened that accurate to the whole back or could you put a 1 degree bevel on the back and only flatten the edge?
-- You never cut a piece to short, you are just prepping that piece for a future project
15249 posts in 2551 days
#11 posted 04-28-2017 10:54 AM
I personally consider it a do-it-once, do it right operation. The back bevel would get it done, but wouldn’t be the way you’d want the cutter to stay forever, i.e., wouldn’t repeat the bevel operation at each sharpening. And at that point, you’d adjust technique or fettle for a cutter that’s no longer beveled.
And, it’s not what this is, but a MF No. 1 cigar shave flat out will not work with a back bevel or a secondary bevel. Tools with those constraints tend to draw me away from anything but a single bevel that’s honed to refresh but otherwise left alone.
