| Forum topic by tpastore | posted 288 days ago | 583 views | 0 times favorited | 9 replies | ![]() |
288 days ago |
Hello all, I am making a table that resembles the aft decking on a 1947 Chris-Craft Deluxe. The table is made with meranti dimensional lumber and meranti plywood for the deck. I built the exterior frame and then brought the pieces to a CNC router house to shape the outer frame and add the slots to the plywood. The pictures below show things dry assembled for the pictures and before any major sanding of the varinsh to start smoothing things out. This was the first of 3 tables. The first one (shown here early on) now has been completed. I ended up filling the slots with tinted epoxy, resanding, varnishing/sanding till flat, then re-striping the white. My complaint is that it seems pointless to make a groove just to fill it in again till it is unnoticeable, and then put the stripes on. So my question is: on my next two tables should I skip the step of adding the grooves in the plywood, just finish the whole thing flat and then add the stripes? Here is a picture of the first table before adding epoxy and sanding: And a picture with photoshopped in white stripes: With the umbrella: |
