Adhesive needed for pvc to mdf smooth side
Forum topic by scribble posted 04-26-2017 02:23 PM 469 views 0 times favorited 10 replies Add to Favorites Watch
View scribble's profile
150 posts in 2134 days
04-26-2017 02:23 PM
Topic tags/keywords: question
I am looking for an adhesive that will allow me to secure my 4” S&D pvc pipes to the smooth side of MDF. I tried the construction adhesive I had on hand as well as some 5 min epoxy and the epoxy held well until I exerted a little force on it trying to get my flex hose inside it.
I appreciate any suggestions.
added Pictures
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
10 replies so far
View nkawtg's profile
272 posts in 1184 days
#1 posted 04-26-2017 02:43 PM
Urethane glue may work, but the epoxy should have.
Perhaps roughening the area on the MDF to be glued would help with adhesion.
View Kazooman's profile
971 posts in 1886 days
#2 posted 04-26-2017 02:51 PM
If I understand correctly, you are trying to secure the end of the PVC to the face of the MDF. I don’t think that will ever be very strong. I would make the hole in the MDF the size of the OD of the pipe and glue the pipe inside the hole, perhaps with a small screw or two to secure it. The wood analogy would be a very weak butt joint as compared to a mortise and tenon.
View Bill1974's profile
124 posts in 2918 days
#3 posted 04-26-2017 03:03 PM
I would try to mechanical mount the pipe and used the adhesive to function as a sealant.
You might have to pre-treat the MDF to seal it and add some strength to the fibers and them bond the pipe to it.
Maybe a couple of pictures of what your looking to do you also help us help you.
View rwe2156's profile
2841 posts in 1414 days
#4 posted 04-26-2017 03:25 PM
What Kazooman said !!!!
#5 posted 04-26-2017 03:49 PM
I see people make them like this all the time with just but jointed but none of them used MDF. I wonder if I just scrap the mdf and go to plywood if the adhesion would be better?
View bigblockyeti's profile
5055 posts in 1654 days
#6 posted 04-26-2017 04:18 PM
Even if you do get a good bond on a butt joint, the point of failure will be moved from the adhesive to the smooth face of the MDF peeling away. Kazooman described what would be your best bet and the method I’ve employed several times with zero failures to date. Roughing up any part of the smooth PVC that will be in contact with epoxy will give it a far greater chance of adhering securely.
View Loren's profile
10100 posts in 3581 days
#7 posted 04-26-2017 04:25 PM
It’s an inherently weak joint I think. I would
just do what you did and add some l-brackets
with screws around the perimeter.
Another approach would be to make the hole
so the pvc goes inside the hole.
View DrDirt's profile
4421 posts in 3675 days
#8 posted 04-26-2017 04:27 PM
+1 Kazooman.
You need a bit more glue surface than just the 3/32 inch edge of the PVC piping.
I would enlarge the hole so that you are inserting the pipe into the MDF, and glue it that way.
View Woodknack's profile
11311 posts in 2313 days
#9 posted 04-27-2017 12:43 AM
Make a ring of MDF to double the glue surface and increase mechanical strength.
-- Rick M,
View RogR's profile
109 posts in 798 days
#10 posted 04-27-2017 04:58 AM
Not really disagreeing with any of the above, but try a polyurethane caulking. A big fat bead around the outside will increase the surface area of the bonding surfaces. In my experience that stuff is never eager to let go of anything once cured.
