Handy tip for a drill depth stop
Forum topic by CiscoKid posted 11-06-2010 09:06 PM 3645 views 0 times favorited 5 replies Add to Favorites Watch
View CiscoKid's profile
CiscoKid
343 posts in 2839 days
11-06-2010 09:06 PM
Topic tags/keywords: tip trick
I needed a drill bit collar for a 9/32” drill bit to keep me from drilling too deeply in a project. I once bought a four piece set of these collars but 9/32” was not one of the sizes included. What to do? Ah ha! You know those fat little rubber bands that are used for banding calves? Worked like a charm. I actually like these better because I don’t have to worry about the setscrew marring my drill bit. Hope this helps someone.
-- Al, Culpeper VA
5 replies so far
View RalphBarker's profile
RalphBarker
80 posts in 2734 days
#1 posted 11-06-2010 09:36 PM
Masking tape can work well, too, as long as one is careful.
CiscoKid
#2 posted 11-07-2010 12:24 AM
True. And I suppose one doesn’t have to worry about the end of the drill bit falling off if you leave it on too long. ; )
-- Al, Culpeper VA
View sedcokid's profile
sedcokid
2731 posts in 3563 days
#3 posted 11-07-2010 02:00 AM
Great Idea..
-- Chuck Emery, Michigan,
View brianinpa's profile
brianinpa
1812 posts in 3688 days
#4 posted 11-07-2010 02:04 AM
At one time I had some plastic tubing from an IV bag that I took home with me after being discharged from the hospital following an operation. I had no idea why I took it, but I thought I would need it some day. Turns out, the tubing worked great for this purpose on smaller drill bits.
View Gene Howe's profile
Gene Howe
10352 posts in 3393 days
#5 posted 11-07-2010 01:31 PM
Another trick is to drill through a small block, and expose only the depth needed. Gotta fiddle with it a little but, you can save it, and others, and reuse them. I have 8 or 10 in a little clear plastic bottle next to my drill bits. All marked with a magic marker.
And Ralph, “careful” is the operative word. After two, even one, hole my tape is shot!
