You get what you pay for.
Forum topic by Rrrandy posted 04-25-2017 11:47 PM 991 views 0 times favorited 21 replies Add to Favorites Watch
View Rrrandy's profile
Rrrandy
212 posts in 506 days
04-25-2017 11:47 PM
About a year ago I purchased the full set of Lee Valley Brad point bits. Not cheap but I wanted a good set. Just out of curiosity I compared them with a set from a big box store. The results are in the pictures. I used a 3/16th inch bit for the comparison. Guess which bit is from Lee Valley…
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
21 replies so far
View Woodknack's profile
Woodknack
11805 posts in 2407 days
#1 posted 04-26-2017 12:15 AM
Is that from a drill press?
Rrrandy
#2 posted 04-26-2017 12:17 AM
- Rick M
Yes, from a drill press.
View waho6o9's profile
waho6o9
8207 posts in 2604 days
#3 posted 04-26-2017 12:24 AM
Amazing results
Woodknack
#4 posted 04-26-2017 12:26 AM
Big difference. I’m still using a set of Black & Decker that I’ve had forever.
Rrrandy
#5 posted 04-26-2017 12:31 AM
It has something to do with bit design I’m guessing…
Woodknack
#6 posted 04-26-2017 12:33 AM
Isn’t that how brad points are supposed to work
View TheFridge's profile
TheFridge
9608 posts in 1513 days
#7 posted 04-26-2017 12:40 AM
None of the ones I’ve used.
Woodknack
#8 posted 04-26-2017 01:28 AM
It was a rhetorical question. A brad point should have two spurs to score the wood and prevent tearout. If your bits don’t have the spurs, they aren’t brad points. The Lee Valley are no doubt sharper and better made. Cheap tools are cheap for a reason.
Rrrandy
#9 posted 04-26-2017 01:46 AM
Rick, the brad point bit in your picture looks like the right hand picture in my post. The LV bits have a “hump” (for scoring the wood) right before the cutting point that I don’t see in your picture.
View WayneC's profile
WayneC
13754 posts in 4124 days
#10 posted 04-26-2017 01:50 AM
That is nice. Which Lee Valley set did you get.
Rrrandy
#11 posted 04-26-2017 01:51 AM
- WayneC
The 1/16” to 1/2” by 1/64”
WayneC
#12 posted 04-26-2017 02:03 AM
Thanks. I will have to check it out.
View papadan's profile
papadan
3584 posts in 3395 days
#13 posted 04-26-2017 02:11 AM
I bought one of these sets from Woodcraft.
BIG, HUGE, MISTAKE! HF has better drill bits. This set has regular twist and brad point and neither kind will drill butter.
View TravisH's profile
TravisH
583 posts in 1962 days
#14 posted 04-26-2017 02:12 AM
I bought the set from Lee Valley last year and kick myself for not doing it sooner. Too many cheap “brad point” just have and up swept cutting edge that are described as spurs and are very much different than on most quality bits.
http://www.homedepot.com/p/DEWALT-High-Speed-Steel-Brad-Point-Drill-Bit-Set-6-Piece-DW1720/202279646
Now my next investment will be to replace my cheap forstner bits.
MrUnix
6767 posts in 2226 days
#15 posted 04-26-2017 02:15 AM
Any drill bit will cut clean holes in wood… as long as they are sharpened properly. Even cheap ones.
