Latest in entry level floor drill presses?
Forum topic by smozes posted 04-25-2017 11:36 PM 2112 views 0 times favorited 14 replies Add to Favorites Watch
View smozes's profile
smozes
26 posts in 878 days
04-25-2017 11:36 PM
With the Porter Cable 15” PCB660DP discontinued, I can’t think of an alternative in that price range. There’s Wen (fake reviews?), and Harbor Freight, which I know too well. The HF 17” 43389 has gotten a decent reputation though.
Otherwise, nothing up to Jet $600 territory. Any ideas?
14 replies so far
View Jack Lewis's profile
Jack Lewis
335 posts in 1256 days
#1 posted 04-25-2017 11:45 PM
Have you checked Grizzly 17” @ $599. Vice HF it might be what you want.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View Woodknack's profile
Woodknack
12402 posts in 2558 days
#2 posted 04-26-2017 12:00 AM
Wen, HF, Shop Fox, Grizzly, are all the same, buy your team colors.
View Woodchuck2010's profile
Woodchuck2010
722 posts in 1036 days
#3 posted 04-26-2017 01:45 AM
I’m very pleased with my WEN.
-- Chuck, Michigan,
View GR8HUNTER's profile (online now)
GR8HUNTER
4939 posts in 890 days
#4 posted 04-26-2017 02:07 PM
was wondering that just the other day Chuck …....if you still would recommend it to a friend :<))
View Bill1974's profile
Bill1974
126 posts in 3163 days
#5 posted 04-26-2017 03:22 PM
Lowes is still selling the PC, they do have two listings for the same DP, one does say it’s discontinued the other says you can order it.
I have the PC, the WEN looks really similar. If the prices are close I think I would go for the WEN because of the slower speeds it is capable of and it’s easier to change the speed.
Hard to tell from the picture but the castings look better on the WEN too. And the table looks easier to clamp to till you make a proper table for it.
View Tedstor's profile
Tedstor
1678 posts in 2811 days
#6 posted 04-26-2017 03:29 PM
Check Tractor Supply. I think they still have some offerings.
View DrDirt's profile
DrDirt
4492 posts in 3920 days
#7 posted 04-26-2017 05:04 PM
Good Call Ted…. I see this:
View LucasAZ's profile
LucasAZ
9 posts in 587 days
#8 posted 04-26-2017 10:53 PM
It looks like there is just a new revision of the Porter Cable drill press, Lowes’ website show it in stock now as the “type 2”.
Woodchuck2010
#9 posted 04-27-2017 07:04 PM
- GR8HUNTER
Yup. Mine was $399, so it was an easy decision for me.
-- Chuck, Michigan,
smozes
#10 posted 04-27-2017 07:52 PM
I just found the PC on Lowe’s but only after selecting a different local store. Listed in stock for $379.
With a 10% coupon, it could still be the most reasonable option. I know people commonly have to fiddle with the chuck and arbor, the table is not designed for woodworking and the minimum speed of 300 is not what it should be, 250. How serious are these shortcomings?
View liamtoh1's profile
liamtoh1
59 posts in 679 days
#11 posted 04-29-2017 04:08 AM
It looks like there is just a new revision of the Porter Cable drill press, Lowes website show it in stock now as the “type 2”.
- LucasAZ
What’s the item number on Lowes.com for the PC?
LucasAZ
9 posts in 587 days
#12 posted 04-29-2017 02:38 PM
- LucasAZ
What s the item number on Lowes.com for the PC?
- liamtoh1
The Lowe’s number is 78742 and the PC number is PCB660DP Type 2
liamtoh1
#13 posted 04-29-2017 03:22 PM
The Lowe s number is 78742 and the PC number is PCB660DP Type 2
- LucasAZ
Thanks. Its not available at my nearest Lowes, but it is available at some other stores not very far from where I live.
LucasAZ
9 posts in 587 days
#14 posted 04-29-2017 04:38 PM
Yeah, I’m not sure why that is with Lowes. Seems like with everything else you can order anything from their website and have it shipped to either your local store or your house, but not larger power tools.
But I do think the PC drill press is a great tool, I don’t think there is any other drill press in it’s price range with 4” of travel. I have had mine for a little over a year now and have had no troubles with it.
The two things I did change were replacing the handle knobs with some wood balls and I replaced the threaded rod on the depth stop with one without a scale on it. The original one worked ok, but if you had the speed nut rotated to where it’s threads and the flat on the depth rod were aligned it could slip.
