Leveling a Router Table Insert
Forum topic by ChunkyC posted 11-06-2010 05:40 AM 1248 views 0 times favorited 7 replies Add to Favorites Watch
View ChunkyC's profile
856 posts in 3185 days
11-06-2010 05:40 AM
Any ideas for leveling a router table insert? My insert sets a little low on a couple corners. The table top is 2 layers of 3/4” MDF. I added setscrews to level the insert but they don’t seem to work. I think the MDF is to soft and the setscrews get “pushed” down when I tighten down the insert screws. They are installed in such a way that the screws can be raised and lowered from the underside. All I have to do is loosen the screws that secure the insert to the top, adjust the setscrews and re-tighten.
I’ve use blue tape to level inserts on my drill press table and it works great but I’m not sure if that will do, maybe it will, I haven’t tried. I had thought about using aluminum tape (the stuff that is used on duct work.) to level it.
-- Chunk's Workshop pictures:
7 replies so far
View richgreer's profile
4541 posts in 3005 days
#1 posted 11-06-2010 03:05 PM
Shims will probably work. You might have to buy a shim set intended for a dado stack and cut each shim in half.
View syenefarmer's profile
485 posts in 3011 days
#2 posted 11-06-2010 04:41 PM
Buy an inexpensive feeler gauge set and make some shims out of the appropriate size or sizes.
View RalphBarker's profile
80 posts in 2700 days
#3 posted 11-06-2010 04:44 PM
I used threaded brass inserts on my router table, and then added a washer and a lock nut on the underside. I used two for each corner, about an inch from the corner, to spread the weight a bit. The lock nut is essential, though, since vibration will tend to loosen the machine screws.
#4 posted 11-06-2010 08:39 PM
All great ideas. I sometimes get stuck on one way of doing things then I can’t see the forest for the trees.
Thanks for the help!
View 1yeldud1's profile
301 posts in 2973 days
#5 posted 11-06-2010 09:07 PM
I use “blue” tape on the MDF zero clearance insert on my table saw (about 6 layers in 3 corners) and it has worked GREAT. I have had it installed for almost 6 months with absolutly no problems !!!!! Id give it a try – I dont think there would be any problems
View sawdust55109's profile
64 posts in 2780 days
#6 posted 11-08-2010 07:52 AM
Had a similar problem with my old router table. Ended up drilling 4 small holes in the corners and used CA to glue in a couple small nuts. Then put in some flat head screws that could be turned up or down.
Worked great.
View Steve's profile
119 posts in 3061 days
#7 posted 11-08-2010 03:00 PM
Drill out the MDF. Then epoxy in some hard wood to mount your adjusters in should help as well.
