Where can I buy 1/4 inch exotics or anyone know of a place that can resaw larger planks?
Forum topic by NoobPhillip posted 04-25-2017 02:09 PM 1026 views 0 times favorited 6 replies Add to Favorites Watch
View NoobPhillip's profile
NoobPhillip
1 post in 599 days
04-25-2017 02:09 PM
Topic tags/keywords: purpleheart walnut wenge zebrawood cherry cedar bubinga padauk
I am working with 1/4 and 3/8 lumber to make small boxes. Currently I can only purchase that thickness at about $30 for two board feet.
I have found much cheaper supply, but comes in usually around an inch. I do not have a band saw.
Anyone know of a place in the area that can resaw to a 1/4 or sells it at that thickness at a decent price?
View Madmark2's profile
Madmark2
405 posts in 790 days
#1 posted 04-25-2017 02:37 PM
Time to learn resawing and invest in a planer . . .
M
View UpstateNYdude's profile
UpstateNYdude
917 posts in 2184 days
#2 posted 04-25-2017 04:15 PM
For exotics you’ll always pay a premium, I don’t think any of the woods outside Cedar, Walnut and Cherry go for anything under $10 a bd ft. even then in some places FAS cherry and walnut go for that.
I don’t know what your options are for buying material near you, but like MadMark said you could get a bandsaw and resaw boards yourself and plane to the desired thickness either using handplanes or a combination of a jointer and planer. Depending on what widths you work in you could easily get away with a small bandsaw with a good resaw blade and auxilary fence, 6” jointer and lunchbox planer for under $1000 new and even less if you can find some good CL deals near you.
I started resawing my own veneer pieces for drawer fronts awhile back and it is nice to be able to process your own stuff.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View DrDirt's profile
DrDirt
4511 posts in 3944 days
#3 posted 04-25-2017 04:35 PM
That is the challenge with exotics – -they are pricey to begin with, and there is a lot of loss as sawdust cutting pieces and resurfacing to 1/4 inch.
Even for domestic stuff – -1/4 is double the cost per BF as 4/4
If you have access to a tablesaw, and the pieces are not too tall – you can resaw on the tablesaw and split 4/4 down the middle and plane it to 3/8 or 1/4
More loss than with the bandsaw, and more limited in height, but doable.
View Rrrandy's profile
Rrrandy
212 posts in 680 days
#4 posted 04-25-2017 04:53 PM
How many small boxes are you going to make? Do a cost analysis. At some point the cost of a bandsaw and planer becomes a wash.
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
View Redoak49's profile
Redoak49
3664 posts in 2190 days
#5 posted 04-25-2017 05:24 PM
Try Ocooch Hardwood….I have had good luck with them.
View McFly's profile
McFly
273 posts in 1229 days
#6 posted 04-25-2017 11:10 PM
- NoobPhillip
Where are you located? I work in a shop that makes laminated handrails from 1/4” stock. Just snagged a bunch of red oak – not exotic, but it fits the dimensions – and a little jatoba.
