Decagonal Disks?
Forum topic by Steven Davis posted 925 days ago 524 views 0 times favorited 1 reply Add to Favorites Watch
View Steven Davis's profile
Steven Davis
98 posts in 1080 days
925 days ago
Topic tags/keywords: jig question router tablesaw plane shaping
I’m making a board game and I need some decagonal disks (flat decagons) on which I can put numbers on the edges.
For my prototype, I used some scrap large-ish dowel discs and free cut the decagons from a template on my bandsaw.
Not pretty and not scalable.
My initial thought is to create a jig similar to a lathe that I can tun 35 degrees and cut each face and then take the decagonal cylinder over to my table saw and cut a whole-lotta disks.
I would make the cuts either with my table saw or a router.
Is this the right approach? Would the router or table saw be better (each face is around 1/2 to 3/4 inch to allow a number to be placed)?
Any good ideas on precise 35 degree rotations?
Thanks for any thoughts!!!
-- Steven Davis - see me at http://www.playnoevil.com/ and http://www.stelgames.com/
1 reply so far
View BreakingBoardom's profile
BreakingBoardom
613 posts in 1247 days
#1 posted 925 days ago
Well first of all, I think you’re starting with the wrong angle. Interior angles on a decagon would be 144, so the complimentary angle that you’d be making the cut at is 36. Being off by 1 degree over 10 sides could add up to be some of the problem. Maybe a good approach would be to make a template by gluing up ten pieces cut like a segmented turner would do. Make little triangles or trapezoids with the proper outer edge length and angles to make the size you want. Then attach the template and use a router and flush trim bit. I think that would be easiest for me. Not sure how I’d do it on a table saw unless maybe if I had the Incra setup.
-- Matt - http://breakingboardom.wordpress.com/
