balancing between centers
« back to Woodturning forum
Forum topic by Karda posted 04-24-2017 11:42 PM 669 views 0 times favorited 21 replies Add to Favorites Watch
View Karda's profile
Karda
953 posts in 459 days
04-24-2017 11:42 PM
I was give a chunk of fire wood to turn. I trimmed as much of the pith as I could. How do I find the center of this , here are pics of the ends.
21 replies so far
View gwilki's profile
gwilki
180 posts in 1379 days
#1 posted 04-25-2017 12:17 AM
Not to be snarky, but why do you need to? Will you be turning this into a spindle of some sort? Since it doesn’t look like the piece’s sides are parallel or straight, even if you could find the exact center of both ends, the piece would likely not be parallel to the ways when you mount it.
-- Grant Wilkinson, Ottawa ON
View MrUnix's profile
MrUnix
6349 posts in 2104 days
#2 posted 04-25-2017 12:19 AM
For a piece like that, the center is where you eyeball it. Once turned round, the centers will be, by definition, dead center.
Karda
#3 posted 04-25-2017 12:29 AM
yes but it will be very of balance, the first pice I mounted was bigger than that but fairly uniform but curved a little, it hrew of as soon as I turned the lathe on, I face plate mounted that one. I had to block the end of the lathe. I don’t want to do any damage to the lathe or me. and when a machine mack a hell of a lot of noise it shouldn’t make it scares the hell out of me.
View jonnybrophy's profile
jonnybrophy
160 posts in 517 days
#4 posted 04-25-2017 12:30 AM
A lil bit down, a lil to the right
you’ll be fine
(i agree, just eyeball it, You could put a bubble level on top if the piece is long, but that wont really help much either)
-- "If she dont find ya handsome, she better find ya handy"
MrUnix
#5 posted 04-25-2017 12:31 AM
Then you didn’t have enough pressure being used on the tailstock.
jonnybrophy
#6 posted 04-25-2017 12:33 AM
Do you have any hand planes?
Trim off where you think there is too much weigh/off center.
I agree it is super scary when the lathe starts jumping.
View Rick_M's profile (online now)
Rick_M
11107 posts in 2285 days
#7 posted 04-25-2017 12:59 AM
Tighten it down like you don’t want it to ever come off, then check it every few minutes because it will loosen.
-- http://thewoodknack.blogspot.com/
Karda
#8 posted 04-25-2017 01:00 AM
ok, i’ll see what I can trim as well thanks
View LeeMills's profile
LeeMills
504 posts in 1206 days
#9 posted 04-25-2017 01:04 AM
This method works the same with spindle orientation. Trim with a hatchet to eyeballed round.
Mount between centers; note the spurs at the headstock are not engaged so the log can rotate (heavy side down).
Adjust then set the spur drive and tighten.
You will probably want to stop and move the centers a few times as the weight changes.
I just trued up about 12 5” cherry blanks that had been drying about two years and adjusted the center at least once on each one.
Start slow and be safe. Very sharp tool helps a lot.
https://www.youtube.com/watch?v=b4xIHTS0yJc
Karda
#10 posted 04-25-2017 01:19 AM
thanks for the video, I’ll try that
View Kelly's profile
Kelly
1918 posts in 2849 days
#11 posted 04-25-2017 03:08 AM
Are you starting off with support from the tail stock. If not, do, until you got your happy round. Since it’s “between centers,” I guess so, so – slow down.
Looking at your photo, you could have altered balance by moving more to the right-ish. Use your tape and make a gob of half measurements and you should be within a half inch or so.
All the foregoing aside, you have just justified a band saw. ;)
Karda
#12 posted 04-25-2017 03:23 AM
I supported with both centers just not tight enough, I did measure after the paint dried and got I thing pretty close to center. I have a new band saw that would cut that piece but when I tried to rip it the saw didn’t cut to good. I think the blade is to fine to rip it so I used the table saw
View papadan's profile
papadan
3584 posts in 3274 days
#13 posted 04-25-2017 04:26 AM
Mike, I wish you were closer to one of us so we could get together and show you how to do things.
Karda
#14 posted 04-25-2017 05:16 AM
yea I do too, but you all have been a great help, This is quite a learning experience
Kelly
#15 posted 04-25-2017 06:03 AM
You should be running about a 3 TPI blade, regardless of width.
