Shooting board question
Forum topic by TopamaxSurvivor posted 929 days ago 1174 views 0 times favorited 17 replies Add to Favorites Watch
TopamaxSurvivor
13192 posts in 1845 days
929 days ago
Topic tags/keywords: stanley 3 4 shooting board
Is a Stanley #3 or 4 suitable for use on a shooting board?
17 replies so far
View cabmaker's profile
cabmaker
1029 posts in 978 days
#1 posted 929 days ago
Depends on the material you are jointing. Condition of your iron obviously would be a factor as well. For the short answer, I would have to say no. A # 5 would be a much better choice. JB
View SouthpawCA's profile
SouthpawCA
237 posts in 1402 days
#2 posted 929 days ago
I’ve done shooting with a Jack plane (preferred) and even a small bench plane. Both with excellent results. However, it all depends on your plane. Is it flat and square? If so, you’re good to go.
-- Don
View Mario's profile
Mario
70 posts in 1565 days
#3 posted 929 days ago
As long as the sole is flat and square to the sides you should have no problem with either one. I carry a small portable shooting board on my toolbag along with a Veritas apron plane (a small block plane) and it works like a charm everytime.
TopamaxSurvivor
#4 posted 929 days ago
I am thinking of tuning up some old planes and was wondering if I could dedicate the smaller ones to the shooting board. I was thinking the #5 would be more of a scrubber to take the worst off before final smoothing. Is a #5 being used like that going to be good enough to make perfect joints? Am I thinking my jack plane will be rougher than it should be?
Mario
#5 posted 929 days ago
I would say that your #5 can definitely take out a bigger bite than your #3 or 4 but if your blade is sharp and sole is flat there is no reason why you shouldn´t be able to use it for smoothing or fine tuning your work, that wide range of use is basically the appeal of the jack plane.
View swirt's profile
swirt
1864 posts in 1141 days
#6 posted 929 days ago
Configuring a jack to shoot would work just fine. The only pain is then having to reconfigure it when you want it to run coarse. You can get by with just the depth adjuster, but usually will require a change in setting of the frog and the chip breaker. So it becomes a bit of a hassle for constant switching back and forth. Better to have two :)
TopamaxSurvivor
#7 posted 929 days ago
Beginning to wonder if I’ll ever get planes figured out and up and running :-))
View studie's profile
studie
604 posts in 1316 days
#8 posted 929 days ago
Was the “coffee lounge” a shooting board? LOL I have yet to use a shooting board other than a make shift one at the job site, they look to be a valuable tool though. I’m working a lot lately but want to make one or two. Could you come over & let’s make a few for gifts? How about a really big one for timber framing?
-- $tudie
View Lochlainn1066's profile
Lochlainn1066
138 posts in 946 days
#9 posted 929 days ago
There is no reason you can’t adjust a jack as fine as a smoother. Both the #4 and #5 have the same adjustments and dimensions.
The solution to the hassle of switching back and forth is to buy a dedicated shooting plane. I find #5’s and other mfr’s equivalents all the time for around $12 at antique stores. Any style will do so long as it is a decent brand.
My first jack was a $12.50 Keen Kutter K5… with the bedrock style bed. Surprisingly while I find #5’s and #3’s everywhere, #4’s are proving to be rare around here.
-- Nate, thegaragestudio.etsy.com
View RalphBarker's profile
RalphBarker
80 posts in 939 days
#10 posted 929 days ago
My experience is similar to those reflected in the other comments. I would add, however, that with harder woods, having a bit more weight in the plane makes it easier. I’ve used a #4 and a #7, but currently I’m using a low-angle #5 (LN with their “hot dog” attachment).
TopamaxSurvivor
#11 posted 929 days ago
Hey Studie, Long time no see:-(( we can make a timber framing shooting board. You get the blade in the frame, I’ll bring the tractor over to push it ;-))
TopamaxSurvivor
#12 posted 929 days ago
Sounds like I may use a 4 for shooting and the jack as a jack. Once I get them set up, I won’t want to be undoing it until I figure out what the heck I’m doing if I get that far :-))
When would a #3 be called for? The plane descriptions talk about a small smoother, but in practical terms, when do you plane users use them or do you even bother with a 3?
RalphBarker
#13 posted 929 days ago
”When would a #3 be called for?”
Small smoothers (#3) can be useful if you have small hands. Otherwise, they tend to be hard to grip. But, they are cute and nice to look at, particularly if bronze. ;-)
View Brian Havens's profile
Brian Havens
194 posts in 1275 days
#14 posted 929 days ago
If the edge of the board is already strait, and you just want to square up the edge, I should think the #4 would be fine. If you are both trying to straiten the edge and square the edge at the same time, then a #5, but I think straitening and then squaring is easier.
Personally, I prefer using a aux fence in a vice instead of a shooting board. I find it much easier, especially with the metal hand planes (vs. wooden hand planes.)
-- Brian Havens, Woodworker http://brianhavens.com
View David Kirtley's profile
David Kirtley
1250 posts in 1167 days
#15 posted 928 days ago
As far as the size, it doesn’t make any difference what you use with a shooting board. The edge of the board guides the blade and not the sole. The thing you might want to consider is a low angle plane for the shooting board. You will mainly be going against end grain. A little block plane would work fine on a shooting board but the only real drawback is that you don’t have much to hang on to.
As far as what you use for a smoother size, it is hand size and blade width that will matter most. Some people like a smaller #3, some might want to go up to a #4-1/2. I prefer my #5-1/2 for a jack to a #5. It just fits better.
