How many use a shooting board regularly
« back to Hand Tools forum
Forum topic by Manitario posted 04-24-2017 02:21 AM 1218 views 0 times favorited 18 replies Add to Favorites Watch
View Manitario's profile
Manitario
2630 posts in 2939 days
04-24-2017 02:21 AM
My last several projects have involved long, wide boards for casework. I find it really difficult to get precise 90 degree crosscuts on my mitre saw despite a lot of effort to tune it, and cross-cutting 8ft long boards on the tablesaw, even with a large cross cut sled is very difficult. I imagine that wide boards used to get cut by hand and then trued up on a shooting board. I’ve also heard of people rough cutting boards on their MS or TS and then using a shooting board to get a perfect 90 degrees.
How many people use a shooting board for wide boards? I’ve seen most of the use for small pieces and/or mitres eg. picture frames.
18 replies so far
View rwe2156's profile
rwe2156
3003 posts in 1536 days
#1 posted 04-24-2017 01:14 PM
For wide boards I don’t use a shooting board for anything over 5”. Plus its very difficult physcally.
If the board is wide treat just like you’re jointing it. I use a #6.
View BlasterStumps's profile
BlasterStumps
758 posts in 495 days
#2 posted 04-24-2017 01:51 PM
I use a jointer plane in these instances and if I really want to be sure I am getting the cut close to 90 I grab a No 7 that has a jointer fence attached. I usually can get fairly close freehand with a jointer plane.
Mostly have used a shooting board for small(-ish) pieces.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View Jim Bertelson's profile
Jim Bertelson
4187 posts in 3220 days
#3 posted 04-24-2017 04:14 PM
I haven’t run into the problem, yet, but then again, I don’t usually make large objects. My RAS will go to 14.5”, and with occasional tuning, will cut a perfect 90 degree, thankfully. You might be able to pick up a used one cheap, if that would help. However, the proper plane should work, as per the above posts.
Interestingly, I was thinking about making a shooting board just recently, but other urgent projects have kept me busy.
Spring finally arriving here, long hard winter. Last year Spring was a month earlier.
Have a good day.
-- Jim, Anchorage Alaska
View MrFid's profile
MrFid
878 posts in 1960 days
#4 posted 04-24-2017 04:42 PM
I use a crosscut sled that I calibrated using the five cut method. See the Wood Whisperer’s video about that for some good suggestions. I wouldn’t shoot anything that wide. My crosscut sled is close enough to perfectly perpendicular that I don’t worry about it. It’s only a few thousandths off over a long run. I very rarely use my miter saw for precision angles.
I haven’t needed to use a shooting board, but I could envision a situation when it would be useful to have one. I just don’t think I’d shoot anything super wide.
-- Bailey F - Eastern Mass.
View JayT's profile
JayT
5731 posts in 2267 days
#5 posted 04-24-2017 04:57 PM
I use a shooting board and plane regularly. My board will only do up to maybe 6 inch wide stock easily, though I’ve done a couple 8 inch pieces in the past. It wouldn’t be that hard to make a board that is capable of shooting wider stock, if that is what is needed.
View Derek Cohen's profile
Derek Cohen
389 posts in 4024 days
#6 posted 04-24-2017 05:07 PM
You can use your bench to shoot.
Here I am match planing two 1/4” panels together. They are weighed down to keep them flat. A #7 jointer is used …
More here: http://www.inthewoodshop.com/Furniture/OneStepBack.html
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View viseone's profile
viseone
12 posts in 461 days
#7 posted 04-25-2017 01:25 PM
I use a shooting board for under 6” long pieces. For longer ones I use my bench and a jointer plane.
Smitty_Cabinetshop
15380 posts in 2674 days
#8 posted 04-25-2017 01:39 PM
The OP asked about wide pieces and shooting end grain, but so many responses are about jointing edges of long boards…
I’m not sure why shooting wide boards would be a problem up to, maybe, 8” or so with normal shooting boards. It requires a second board at the other end of the bench, to hold the piece parallel to bench top, but other than that shouldn’t pose a huge issue for as often as it might be required. If boards are typically wider than that, might need a bigger shoot board.
Do I shoot wide boards? No. RAS does a great job with those cuts.
View TheFridge's profile (online now)
TheFridge
9719 posts in 1542 days
#9 posted 04-25-2017 02:37 PM
I don’t hesitate shooting wider stock as I made mine big 16”ish. Have only used half the capacity but I would if I needed to.
Jim Bertelson
#10 posted 04-25-2017 03:10 PM
Oh, and as per MrFid, my super sled has a 25” capacity, so takes care of crosscuts on panels up to that size. For bigger panels, I have a rather gigantic panel sled with a front fence. My nemesis is the wide and long stuff, and that is always tough.
BlasterStumps
#11 posted 04-25-2017 03:51 PM
Do you have a circular saw? Not always but sometimes, I will use a circular saw against a guide to get a fairly close 90 degree endcut. It’s not the best method, but if for some reason your mitre saw just won’t do it, then there would be that option.
- Manitario
Derek Cohen
#12 posted 04-25-2017 04:01 PM
Ok, I demonstrated the way to joint a long edge. However, shooting a wide crosscut is no different. You need to knife in the square, and then plane to it – use a jointer plane exactly as I have shown. What the knifed lines. A little here and a little there.
Using tablesaws (I have an “accurate” sliding table), crosscut sled, mitre saw … none of these is accurate enough … anyway, they are not for the OP – not much point in saying what power tools work for you when he is asking how to use a handplane.
Woodworking is about working to a line.It is not diffrent in this case, just at the ends of the board.
Regards from Perth
Derek
View builtinbkyn's profile
builtinbkyn
2529 posts in 996 days
#13 posted 04-25-2017 04:16 PM
Regards from Perth
Derek
- Derek Cohen
I’m sure it works just fine and you’re careful, but those bricks near those nice sharp bench tools give me the heebie jeebies :O How about using cauls?
-- Bill, Yo!......in Brooklyn & Steel City :)
MrFid
#14 posted 04-25-2017 04:55 PM
- Jim Bertelson
That’s about the capacity of mine as well.
Manitario
#15 posted 04-25-2017 05:31 PM
Thanks for the replies everyone. It sounds like most people have a good enough setup with their MS/RAS/TS to not have to shoot wide boards. It tempts me to look at different MS, have also been kicking around getting a big RAS (would be nice with some of the large slabs I cut). I have a large TS sled but as Jim said, the wide, long stuff is really difficult to cut this way. Sounds like in theory that shooting endgrain on wide boards could be done with the right setup but maybe not the most practical.
