Craftsman Professional 14" bandsaw
Forum topic by Rrrandy posted 04-24-2017 01:43 AM 1134 views 0 times favorited 18 replies Add to Favorites Watch
View Rrrandy's profile
Rrrandy
212 posts in 653 days
04-24-2017 01:43 AM
Does anyone else on this site own one? I have a few questions but if no one else owns one I’m not going to waste time listing my questions/comments.
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
18 replies so far
View dbw's profile
dbw
208 posts in 1811 days
#1 posted 04-24-2017 11:37 AM
I have one of these. Works well.
-- measure 3 times, cut once
View bdresch's profile
bdresch
148 posts in 1783 days
#2 posted 04-24-2017 11:43 AM
If it’s the cast iron Delta clone run away fast (I own one and its junk) If it’s the welded steel Rikon clone I’ve heard they are fine.
The cast iron one is not stiff enough to tension a 1/2” blade. The upper casting deflects so much it’s impossible to keep the guide post parallel to the blade.
View ArtMann's profile
ArtMann
1106 posts in 991 days
#3 posted 04-24-2017 03:17 PM
I have one of the steel frame type that is made by Rikon. It has proven to be a fine low cost option with one exception. It uses the absolute worst blade guides I have ever tried to use. If you have a lot of patience then it could be a good saw. Just don’t change blades very often.
View GR8HUNTER's profile
GR8HUNTER
4920 posts in 887 days
#4 posted 04-24-2017 03:35 PM
MAYBE this will help you out :
http://lumberjocks.com/reviews/3258
GOOD LUCK :<))
Rrrandy
#5 posted 04-24-2017 07:18 PM
- dbw
dbw, is this the one?
View dbw's profile
dbw
#6 posted 04-25-2017 11:43 AM
yup.
View dbw's profile
dbw
#7 posted 04-26-2017 12:00 PM
One thing I need to mention is I have to re-adjust the upper guides every time I move the guide post for a thickness change. I also devised a creative way to make guide adjustments and blade changes 100% tool-free.
19247 posts in 2031 days
#8 posted 04-26-2017 12:20 PM
I have one. I tend to agree with comments above. Works for me. Guides seem to be its biggest drawback.
View edapp's profile
edapp
139 posts in 1604 days
#9 posted 04-26-2017 12:32 PM
I have this saw and have mixed feelings about it. For the price, i cant complain. I wouldnt have anything other than a small benchtop bandsaw if it werent for this being on the market. Now at the same time i will be upgrading this saw whenever possible due to several drawbacks.
I have had the saw stall on me MANY times when trying to resaw. New blades adjusted well, slow feed etc.
3 out of the six bearing blade guides has seized up so far. Not to mention the PITA they are to adjust.
The table does not secure to the base well enough.
However, at that price, i am just glad i have a 14” bandsaw and will deal with it until i can upgrade.
Rrrandy
#10 posted 04-27-2017 12:59 AM
- dbw
Why don’t you share with the rest of us? :)
#11 posted 04-27-2017 01:24 AM
- dbw
Why don t you share with the rest of us? :)
- Rrrandy
Yeah, please share.
View Woodmaster1's profile
Woodmaster1
1060 posts in 2762 days
#12 posted 04-27-2017 01:41 AM
It s not exactly the same as a Rikon. They have cheapened some the features. As for the Rikon I don’t have trouble with adjusting the guides but I am going to buy the upgrade package.
View TravisH's profile
TravisH
622 posts in 2110 days
#13 posted 04-27-2017 02:06 AM
I have one in my shop and overall have been happy with it. Agree with the guide and thrust bearings being an issue.
View dbw's profile
dbw
#14 posted 04-27-2017 12:14 PM
I will attach a few pics this weekend. In the mean time I need to tell you I replaced ALL the bearing with sealed bearings. Including the bearings on both wheels and the bearings on the idler pulley. The bearings on the wheels and the idler pulley have to be pressed in. I went by my local Sears Auto Center and I asked one of the technicians to press them in for me. $20 makes a great lubricant :)
ArtMann
#15 posted 04-27-2017 03:22 PM
Sealed bearings are a great idea. The OEM ones fail regularly. As it turns out, the bearings are the same size as those used for skate boards and you can get a tube of 10 of them economically. If the bearings aren’t sealed, routine oiling helps a lot.
