Advise on Edge Joining thin stock for Pizza Peel
Forum topic by patcollins posted 11-05-2010 12:22 AM 1932 views 0 times favorited 5 replies Add to Favorites Watch
View patcollins's profile
patcollins
1687 posts in 3042 days
11-05-2010 12:22 AM
I am wanting to make a pizza peel, so I got some 1/2” red oak and am wondering if I just edge glue it if it will be strong enough. Thought about putting something like an inlay in it but I don’t think i have the skills yet to make something that looks alright. The handle is going to be one long 2” wide piece with two 6” pieces on either side of it.
5 replies so far
View richgreer's profile
richgreer
4541 posts in 3252 days
#1 posted 11-05-2010 12:28 AM
If you glue it properly it should be strong enough. Gluing it properly means good, clean, straight and flat edges and tight (but not too tight) clamping.
After gluing it up, you may want to thin it down some with a plane and/or sander. I’ve taken some glued up panels down to 3/16” and had no concerns about adequate strength.
Yes, the glue will be stronger than the wood around it.
View Gene Howe's profile
Gene Howe
10988 posts in 3606 days
#2 posted 11-05-2010 01:33 AM
Rich is, of course, correct. But i you want to have some fun on the next peel, try a butter fly inlay. Looks pretty sharp, too.
View shipwright's profile
shipwright
8133 posts in 2975 days
#3 posted 11-05-2010 02:24 AM
I edge glue shop made veneer around 3/32” to 1/8” all the time. I use stretched masking tape for the clamps. never had a problem with the glue joint. (other than PVA glue receding a tiny bit over time.) It would work even better on thicker stock.
View intheshop's profile
intheshop
58 posts in 3016 days
#4 posted 11-05-2010 03:34 AM
In the current issue of Woodsmith magazine (no.191) they make a pizza peel. They glued together pieces 1/2” thick and then planed/sanded them down. Just another option.
-- Fast is fine, but accurate is final. The real trick is learning to take your time when you're in a hurry. - Wyatt Earp
View Frankie Talarico Jr.'s profile
353 posts in 3534 days
#5 posted 11-05-2010 03:46 AM
I’m with shipwright on glueing 1/16” veneers, Holds strong.
If that doesn’t float your boat, they make a “glue joint” router bit. It gives more surface to hold on to,(kind of zig-zag shape), and also aligns your top and bottom. Just make sure to practice before you run the actual piece, and line it up just right.
That’s the way to go if you’re not confdent in making more advanced cut on the table saw. If you do, then why not make a 1/8” spline and run the parts on a tall fence, vertically, making a slot to insert your concealed spline. you’ll only need like a 1/4” in depth on either side.
Good luck, keep us informed on your chosen route.
-- Live by what you believe, not what they want you to believe.
