Dado joints separating one year later
« back to Joinery forum
Forum topic by JohnnyBoy1981 posted 04-23-2017 05:23 PM 1292 views 0 times favorited 30 replies Add to Favorites Watch
View JohnnyBoy1981's profile
JohnnyBoy1981
211 posts in 314 days
04-23-2017 05:23 PM
Topic tags/keywords: dado joint separating
I built this decorative bench a year ago. I had just started trying woodworking, and I didn’t really have any idea what I was doing. I tried using dado joinery for the first time, but I had to use an old router I rescued from a pawn shop and free hand it (at that time I thought a ‘jig’ was an Irish dance or something). I reinforced parts of the bench with wood screws since I didn’t really trust my work. I tossed three coats of a red indoor/outdoor paint on it (which is starting to fade already) and set it outside my house on the north side of the house absorbing the cold winds.
I noticed this year that the dado joints are beginning to separate. I can’t recall if I used wood glue in them or not, but I think so. Is this happening because of wood movement? Humidity levels? And can I do anything to fix it? The bench still holds my weight, and seems sturdy, it just looks tacky now.
30 replies so far
View Loren's profile
9776 posts in 3525 days
#1 posted 04-23-2017 05:49 PM
Take a look at the orientation of the growth
rings on the part that’s separating.
View Rick_M's profile
Rick_M
10853 posts in 2257 days
#2 posted 04-23-2017 06:23 PM
Hard to be sure through the paint but it looks like the grain is oriented the wrong way in the small dividers, they shrank.
-- http://thewoodknack.blogspot.com/
View papadan's profile
papadan
3584 posts in 3245 days
#3 posted 04-23-2017 06:30 PM
Squirt some glue into the openings and shoot a few big screws to pull it back together.
View bondogaposis's profile
bondogaposis
4542 posts in 2228 days
#4 posted 04-23-2017 06:36 PM
It looks like you used construction lumber and now the boards have dried and shrunk. Can you draw the joints tight w/ clamps? If so, glue and screw like papadan recommends.
-- Bondo Gaposis
Rick_M
#5 posted 04-23-2017 06:54 PM
To clarify, the end pieces have grain oriented vertically, the dividers are oriented horizontally so they​ shrank in different directions. You could try forcing them together but I believe that would be a mistake. I would leave it alone and chalk it up as a learning experience.
JohnnyBoy1981
#6 posted 04-23-2017 07:17 PM
Here’s a close up of one of the two vertical dividers in the middle of the bench. The sides have the vertical grain pattern too. The horizontal top and bottom boards have horizontal grain direction. How should I have done this differently? In what direction does a piece of wood expand and contract?
papadan
#7 posted 04-23-2017 07:23 PM
To me it just looks like you forgot the glue or your glue was not waterproof for outdoor use. Can you take a picture of the whole bench for us.
#8 posted 04-23-2017 07:24 PM
wood cups opposite the growth rings. Probably
the top board is oriented so it’s cupped upward
with repeated sun and moisture exposure. The
board edges would cup the other way if it were
flipped over and the joints probably wouldn’t
open up that way.
View jbay's profile
jbay
1944 posts in 776 days
#9 posted 04-23-2017 07:27 PM
I would just drown it in glue and clamp it closed and forego the screws so that you don’t have to deal with screw holes.
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View HorizontalMike's profile
HorizontalMike
7736 posts in 2791 days
#10 posted 04-23-2017 07:47 PM
At this point I am going to suggest clamping it and installing wood screws to hold it together. IMO, the mixed orientation calls for screws. I don’t think you have room to put plugs over the screws either.
Just my 2-cents…
View Rich's profile
Rich
2114 posts in 466 days
#11 posted 04-23-2017 07:55 PM
Another issue with the grain running vertical in those panels is that you screwed into end grain. Screws don’t hold well like that. Going into the long grain along the side of the board is better, since the screw threads bite into the grain and hold better.
-- No matter how much you push the envelope, it'll still be stationery.
View Aj2's profile
Aj2
1233 posts in 1675 days
#12 posted 04-23-2017 08:51 PM
Looks like the wood bowed up and away.
Just normal wood movement.
-- Aj
Rick_M
#13 posted 04-23-2017 08:51 PM
Nevermind my post, like I said, was hard to see.
Here s a close up of one of the two vertical dividers in the middle of the bench.
- JohnnyBoy1981
JohnnyBoy1981
#14 posted 04-23-2017 09:18 PM
- papadan
Here’s a pic of the entire bench as it stands now:
JohnnyBoy1981
#15 posted 04-23-2017 09:20 PM
I need to read some more of my beginner’s woodworking books, I guess. So would I look at the end grain of each board, and cut them (if possible) so that any expansion would go inwards or toward places where two boards connect thereby driving them together?
showing 1 through 15 of 30 replies
