Ideas for quick and easy router table insert plate or way to mount router
Forum topic by juicegoose posted 11-04-2010 09:27 PM 2385 views 0 times favorited 10 replies Add to Favorites Watch
View juicegoose's profile
juicegoose
117 posts in 3026 days
11-04-2010 09:27 PM
Guys I’ve got a triton on the Xmas list but until then all I have is my pc-690. Yes it’s a small router and not ideal for table use but I’ve got to make some doors this weekend and need to mount it somehow for a rail and stile bit set. The router curently rests in a d handle base but I’ve got the fixed and plunge base just sitting around as well. My thought was to simply take a piece of 3/4” mdf and screw it to the bottom. I can clamp a simple fence onto this but will it be sturdy enough or should I double up the mdf or just use 3/4” ply instead of mdf??
Naturally I need to keep this cheap and quick.
10 replies so far
View TheDane's profile
TheDane
5399 posts in 3627 days
#1 posted 11-04-2010 10:00 PM
juicegoose—With a 3/4” MDF table top, I’d be concerned about getting enough of the bit seated securely in the collet to a) run safely, and b) get a clean cut (vibration could be a problem).
View Vrtigo1's profile
Vrtigo1
434 posts in 2955 days
#2 posted 11-04-2010 10:18 PM
MDF would probably get the job done, but I would be worried about it deflecting depending on how big of a piece you used. As TheDane said, you might have issues with the thickness of the MDF not allowing the bit to protrude through far enough. I think Lowes sells low end router tables that will fit a PC router. Your best bet might be picking one of those up and then returning it when you’re done.
juicegoose
#3 posted 11-04-2010 10:19 PM
I don’t have the router in front of me but couldn’t I just adjust the height in the fixed base. I know it rotates to adjust depth of cut not sure how much it would go though.
juicegoose
#4 posted 11-04-2010 10:22 PM
Thanks Vrt for the router table idea but not one to buy use then return when I’m done.
Would a piece of plexiglass do better given that it’s 3/8” thick or so?
View NBeener's profile
NBeener
4816 posts in 3138 days
#5 posted 11-04-2010 10:23 PM
On page 9 of Bill Hylton's book, on router tables, he shows an example of what he calls the Po’ Boy Router Table.
I bet you could throw one together pretty quickly !
-- -- Neil
juicegoose
#6 posted 11-04-2010 10:45 PM
NBeener – Freakin brilliant!!!!!
NBeener
#7 posted 11-04-2010 10:46 PM
I’m sayin’ ..... :-)
-- -- Neil
View intheshop's profile
intheshop
58 posts in 2802 days
#8 posted 11-05-2010 03:40 AM
My first router table was a piece of 1/4” ply with a sturdy frame of 1×3 oak underneath that kept the ply from flexing. worked out pretty well.
-- Fast is fine, but accurate is final. The real trick is learning to take your time when you're in a hurry. - Wyatt Earp
View Robsshop's profile
Robsshop
907 posts in 2939 days
#9 posted 11-05-2010 08:03 AM
Juicegoose, not an expert on the subject but I tend to research as much as possible when it comes to woodworking and when I was educating My self on routers and tables almost everything I came across on the subject of using large router bits in undersized routers is a dangerous proposition but if You do decide to do so,mounting it to a table top is a must ! With larger bits vibration is always a factor so it is best to have a stable,flat and hefty top.MDF is commonly used with good results. I do recommend reading up on do’s and don’t’s and and as always be safe !! Good luck .
-- Rob,Gaithersburg,MD,One mans trash is another mans wood shop treasure ! ;-)
View Timthemailman's profile
Timthemailman
326 posts in 2740 days
#10 posted 11-10-2010 09:50 PM
Here is a small shop built table
http://www.bobsplans.com/BobsPlans/RouterTable/RouterTable.htm
And this is a fast and easy one also good for a back up or portable table
http://www.woodworkingtips.com/etips/etip040700wb.html
