Mallets
« back to Hand Tools forum
Forum topic by Rrrandy posted 04-22-2017 07:52 PM 788 views 0 times favorited 18 replies Add to Favorites Watch
View Rrrandy's profile
Rrrandy
212 posts in 626 days
04-22-2017 07:52 PM
Hey guys, show me your go to mallet(s). Not the one you keep in the glass showcase but the one you use daily. I know some of you guys have ten or twenty but just pick one or two that you use the most. Here are my two…my only two.
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
18 replies so far
View BlasterStumps's profile
BlasterStumps
896 posts in 587 days
#1 posted 04-23-2017 01:07 AM
I just recently turned myself a carvers mallet but haven’t had an opportunity to use it yet so can’t say it is a go-to yet.
My soft-blow mallet is something I use almost everyday when out working in my shop. Its a Great Neck brand or something like that. It is a 32 oz soft and hard face. Wonderful tool.
And then I use the two Warrington style for most things where I need a steel hammer. The small one is a 10 oz and the larger one is at least 14 oz or larger.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View Dave Polaschek's profile
Dave Polaschek
2656 posts in 729 days
#2 posted 04-23-2017 01:17 AM
My go-to mallet was slapped together out of cheap pine.
-- Dave - Minneapolis
View Karda's profile
Karda
1286 posts in 701 days
#3 posted 04-23-2017 02:17 AM
my first projects on y lathe are mallets, 2 from 2×4s and the big one from maple log
View HokieKen's profile
HokieKen
6293 posts in 1286 days
#4 posted 04-23-2017 02:28 AM
Made this last week to chop some mortises, has become my main chisel mallet.
-- Kenny, SW VA, Go Hokies!!!
View waho6o9's profile (online now)
waho6o9
8427 posts in 2724 days
#5 posted 04-23-2017 02:33 AM
Made this mallet with my new plane I received from Ripthorn from the last Surprise tool swap.
Thanks again buddy the plane works well.
The mallet’s held together with just a friction fit as there’s no glue or mechanical fasteners. And I’ve
used and abused it and it works without any problems.
waho6o9
#6 posted 04-23-2017 02:34 AM
- HokieKen
That’s what broke your chisel Kenny, good job!
View MrUnix's profile
MrUnix
6943 posts in 2346 days
#7 posted 04-23-2017 02:34 AM
Made from recycled fabric softener jugs and other stuff
BlasterStumps
#8 posted 04-23-2017 02:36 AM
Nicely done Kenny. I made a few different wooden mallets that I thought would work for chisel mallets but I have tinitis real bad and when I hear the noise from the wooden mallet hitting the chisel, it sets my tinitis off. I had to give up on the wooden mallets. Now I use the soft blow hammer. No noise to deal with. It’s heck getting old.
- HokieKen
BlasterStumps
#9 posted 04-23-2017 02:38 AM
I like your maple mallet. Pretty wood. It ought to do the job.
Mike
- Karda
HokieKen
#10 posted 04-23-2017 02:42 AM
Nicely done Kenny. I made a few different wooden mallets that I thought would work for chisel mallets but I have tinitis real bad and when I hear the noise from the wooden mallet hitting the chisel, it sets my tinitis off. I had to give up on the wooden mallets. Now I use the soft blow hammer. No noise to deal with. It s heck getting old.
- BlasterStumps
I put leather on one of the faces and I have also started capping my chisel handles with leather. Definitely a different sound with the leather in there. Not sure if it would help with your tinitis or not but may be worth a try?
View bandit571's profile
bandit571
21300 posts in 2830 days
#11 posted 04-23-2017 02:49 AM
Spalted maple..
Used a skinny mallet as a pattern to make one to fit the hands better..
Gave it a coat of The Brew…..for a dark colour like walnut….been in hard use ever since
View papadan's profile
papadan
3584 posts in 3516 days
#12 posted 04-23-2017 07:12 PM
Only mallet in my shop. LOML uses it mostly to keep me awake!
Rrrandy
#13 posted 04-23-2017 07:16 PM
- papadan
On top of your head or up along side?
papadan
#14 posted 04-23-2017 07:25 PM
That depends on the angle I’m sleeping at, usually up the side!
View JADobson's profile
JADobson
1207 posts in 2258 days
#15 posted 04-23-2017 09:21 PM
From bottom to top:
Oak mallet made from wormy pallet wood. This I’d my go to for destructive tasks like hitting metal.
Maple mallet with walnut faces. One of my very first woodworking projects. Inside has holes hollowed out and filled with lead shot. This one helps to fit joints together or to take them apart. Also works well for driving my 1/2” mortise chisel.
Poplar carving mallet. This is my most used mallet. Wood is a bit soft but it works well. Turned it from a pattern in fine woodworking.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
