Band Saw Blade question......
Forum topic by Jim posted 11-04-2010 11:52 AM 1027 views 0 times favorited 3 replies Add to Favorites Watch
View Jim's profile
Jim
32 posts in 3121 days
11-04-2010 11:52 AM
Topic tags/keywords: pine cedar walnut bandsaw rustic
Greetings!
I have a craftsman 80 inch bandsaw and I want to find the best blade to center cut a small log (2 to 5 inch diamater). I asked a local tradesdude and he said to get a “rough cut” blade. One woodworking site talked about hook tooth, skip tooth and regular??? It said that the regular blade was not good for “resawing”. My question’s are: what does “resawing” mean, and which blade do y’all recommend? And what size?
Thank you!
Jim
-- All who wander are not lost.
3 replies so far
View lew's profile
lew
12509 posts in 3994 days
#1 posted 11-04-2010 02:33 PM
A resaw blade is usually very wide- as wide as your saw can handle (mine is 3/4”) and has the fewest teeth for the size.
Here is a site for some information http://www.highlandwoodworking.com/woodslicer-resaw-bandsaw-blades.aspx
View David Kirtley's profile
David Kirtley
1286 posts in 3236 days
#2 posted 11-04-2010 03:42 PM
Resawing is taking a large piece and slicing off specifically dimensioned lumber. It could be taking off thin pieces for a veneer or cutting lumber out of a big piece of wood.
The general consensus is that WoodSlicer and Timberwolf blades are the best for resawing but there might be a few other good ones but you won’t go wrong with these.
There are various tooth shapes and spacing to achieve a clean cut depending on the material, blade speed, and feed rate.
The width of the blade will generally affect the straightness of the cut, with a wider blade for straight cut and narrow blade for tighter curves.
View Gregn's profile
Gregn
1642 posts in 3222 days
#3 posted 11-04-2010 04:02 PM
The blade I use for resawing is a Timber wolf brand that is 3/4” wide with a 4 degree hook and 4 teeth per inch. The tooth design of the hook and the 4 teeth per inch help to remove the sawdust while cutting. Note blade speed and feed rate will also affect the cut, the slower the better is what works for myself.
