Veneer cutting
Forum topic by Chessnut posted 289 days ago 203 views 0 times favorited 7 replies Add to Favorites
View Chessnut's profile
Chessnut
23 posts in 293 days
289 days ago
Topic tags/keywords: veneer paper cutter
Hi all, I’m facing a dilemma whether to purchase a paper cutter to cut my strips of veneer for my chessboards or to just use a straight edge and a blade. If I did go the paper cutter route which cutter, the old fashioned guillotine with curved blade or the rotary setup?
-- Mike, Airdrie Alberta
View GaryK's profile
GaryK
8541 posts in 516 days
289 days ago
I have tried various paper cutters and none have worked well. They tend to push the veneer out of the
way making a straight cut very hard.
A straight edge and blade does a much better job.
4486 posts in 746 days
289 days ago
In my limited experience, I agree with Gary.
View Rich_S's profile
Rich_S
54 posts in 393 days
289 days ago
How wide of strips do you want to cut? I use a heavy aluminum straightedge (3/4” thick by 3 1/2” wide with a laminate on the face) with either a stiff blade in an Xacto or an Olfa rotary cutter for most of my work. It provides adequate heft to hold material flat and prevents me from having to apply tons of pressure to the straightedge. I haven’t had much success with a paper cutter either, even after sharpening the blade to a death defying razor edge. When I need narrow strips, such as for banding, then I use an Ulmia strip cutter.
-- Rich, Madison WI
View rikkor's profile
rikkor
8362 posts in 403 days
289 days ago
Heavy straight edge and an Xacto knife.
-- Maplewood, MN
View Catspaw's profile
Catspaw
118 posts in 343 days
288 days ago
What about a mat cutter?
-- arborial reconfiguration specialist
View CharlieK's profile
CharlieK
15 posts in 321 days
277 days ago
I have a friend who does some really fabulous veneer work, and lots of it. He will use a small metal shear to cut pieces like this. It is like an industrial grade paper cutter. It looks something like this: http://roperwhitney.com/shearing/2-20.cfm If you are planning to make a lot of chessboards then it might be worth it, but if you can’t justify one of these then I would suggest a straight edge and a knife.
View Sawdust2's profile
Sawdust2
868 posts in 616 days
277 days ago
I learned to do it with a veneer saw and a straight edge.
I’ve also used a scalpel.
Three quick swipes with the veneer saw and it’s done. The scalpel tends to be too flexible to cut a long piece.
Bookmark And Share This Page
