Making WWPA 105 Shiplap siding
Forum topic by YESServices posted 04-22-2017 01:58 PM 745 views 0 times favorited 3 replies Add to Favorites Watch
View YESServices's profile
YESServices
1 post in 424 days
04-22-2017 01:58 PM
Topic tags/keywords: shiplap siding wwpa 105 dutch german cove router router bit
Any ideas on how to make WWPA 105 shiplap siding? I’m new to woodworking…I thought I could make it use a router, so I went and purchased a router and router table, but now I’m not so sure. Can this be done with a router, and, if so, what bit(s) should I buy? If not, what tool should I buy?
3 replies so far
View bondogaposis's profile (online now)
bondogaposis
4760 posts in 2375 days
#1 posted 04-22-2017 02:48 PM
How many lineal feet do you intend to run? A shaper would be a better tool if you are going to be making large quantities of siding. A router could be used with a panel rising bit, then cutting the rabbet on the table saw with a dado will be faster than using a router. Here is the type of bit you’d need. You will want to slow your router way down when using large bits like that.
-- Bondo Gaposis
View Rich's profile
Rich
2970 posts in 613 days
#2 posted 04-22-2017 03:09 PM
I use this bit to raise panels for interior/exterior doors. The radius of the cove is 1-1/2”, slightly greater than the 1-1/8” that the WWPA standards call for.
Keep in mind that this is a 3-1/2” diameter bit. Be sure your router table can accommodate it. Like Bondo said, you need to slow your router all the way down for a bit that big. You might need to make your cuts in multiple passes, depending on the horsepower of your router. A feather board mounted to the fence will help keep the wood flat against the table top.
View Woodknack's profile
Woodknack
11774 posts in 2404 days
#3 posted 04-23-2017 01:02 AM
