New cabinet saw
Forum topic by Murf2499 posted 11-03-2010 11:13 PM 1243 views 0 times favorited 6 replies Add to Favorites Watch
View Murf2499's profile
Murf2499
20 posts in 2771 days
11-03-2010 11:13 PM
In the next few days I will be placing an order for a new cabinet saw to replace my Ridgid hybrid saw. I have done lots of reading and have decided Grizzly offers the best value for my needs. My last dilema is standard or extension rails. The G1023RL has 26” ripping capacity, the G1023RLX has 52” ( the Ridgid hybrid has 36” ripping capacity). I have a basement shop that I am currently expanding. Althow I will now have double the space, it is still narrow. I am basically putting two rooms together one 12×22 and another 13X20. I feel like this saw is a long term investment so it should have all the capacity available, on the other hand I dont want to bog down my narrow shop with a 72” wide saw. Looking for advice!!
-- Murf, Clifton Park, NY www.murphycustomwoodworking.com
View Viking's profile
Viking
880 posts in 3160 days
#1 posted 11-03-2010 11:27 PM
Murf;
I don’t think you can ever have too much saw. Perhaps you might get a mobile base with extension to the right so you can move it if you need the space for other work. I am now considering buying the longer rails for my cabinet saw.
Good Luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View canadianchips's profile
canadianchips
2600 posts in 2961 days
#2 posted 11-03-2010 11:37 PM
What are you mainly going to cut with it ?
I bought my Table saw without rails. After 1 year I quickly made an extension. I did a lot of kitchen cabinet work. My suggestion is mount your saw on wheels. Then you can move it to one side when you are not using it.
View Bob42's profile
Bob42
456 posts in 3755 days
#3 posted 11-03-2010 11:53 PM
I just bought a Jet 50” from craigs list. My shop is a one car garage so you can imagine how tight it was. So I took the chance and cut the rails and the wood extension to 36”. I bolted the rails to the wood extension and then hinged it with HD door hinges. With the exception of the kerf cut it is dead on. I am finishing it up with folding legs. Now I can get past it and move the saw if needed as it is on wheels. I would go with the larger rails and maybe do something like I did.
-- Bob K. East Northport, NY
View newwoodbutcher's profile
newwoodbutcher
733 posts in 2814 days
#4 posted 11-04-2010 12:13 AM
I would go with the biggest one I could fit. I was pleasantly suprised with how much room I still had when I installed the new Griz 691. The extra length (and work surface) make a very big difference. By the way I’m very happy with the new Griz
-- Ken
Murf2499
#5 posted 11-04-2010 01:47 AM
Thanks for the feedback, you reinforced what I already knew, go big or go home!!! Thanks all, the mobile base will solve all concerns. Thank you!
View knotscott's profile
knotscott
7980 posts in 3340 days
#6 posted 11-04-2010 01:58 AM
You should be able to slide the front rail to the right, thus robbing ~ 10” of rip capacity from the left and adding it to the right. Since it’s a left tilt saw, you’re not likely to miss it.
