garden tool hanging storage
Forum topic by Belg1960 posted 11-03-2010 11:07 PM 4556 views 0 times favorited 5 replies Add to Favorites Watch
View Belg1960's profile
1061 posts in 3002 days
11-03-2010 11:07 PM
Guys, I thought I would ask if anyone has ever made something like this instead of trying to re invent the wheel, so to speak. I want to make brackets to hang shovels rakes and the like any ideas would be helpful. Thanks Pat
-- ***Pat*** Rookie woodworker looking for an education!!!
5 replies so far
View TJ65's profile
1376 posts in 2986 days
#1 posted 11-04-2010 08:14 AM
sorry cant help with the making of it but have you googled it and just looked at some pics. That will give you some idea of what to look for.
Good luck. It sounds like a good idea.
-- Theresa,
View Gregn's profile
1642 posts in 2920 days
#2 posted 11-04-2010 05:19 PM
Not sure of what your looking for or comparing to for ideas. One of the things I do is use water pipe with 2x material for hanging items that don’t fit on shelves. If you could post some pics of the space your working with would help to make suggestions as how to make the brackets or storage area.
View dbhost's profile
5687 posts in 3168 days
#3 posted 11-04-2010 05:27 PM
There is pre made track with “tension hooks” that I use. It’s cheap, very easy to install, and allows me to adjust for maximum garden tool density.
-- My workshop blog can be found at, YouTube Channel
View CoolDavion's profile
434 posts in 3761 days
#4 posted 11-08-2010 12:05 AM
I made mine using a french cleat system with 3 different holders.
First was the simple screw type
the other two were
- a short 1 by 3 attached to a cleat
- a couple short pieces of plywood with a space between attached to a cleat
-- Do or do not, there is no try!
View Dennisgrosen's profile
10880 posts in 3052 days
#5 posted 11-08-2010 12:34 AM
take a long board as you want
and then you make two holes with 2-2½ inch between angled 15-20 degrees
the hole size anything from one to two inch depending on the dovels you have
the dovels shuold bee a little over a foot long or more again dependig on how many
shovels you want in the same place :-)
the next set of holes you just make room enoff between each pair so you are sure
you can have two of the wides garden tool beside each other with a few inches of free room
or you can make them as wood brackets /console´s in pairs
