Plain old wood oil
Forum topic by RussellAP posted 04-21-2017 02:16 PM 1130 views 0 times favorited 32 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2308 days
04-21-2017 02:16 PM
I’m looking for a plain wood oil that doesn’t have any hardeners in it. Just oil.
I want to try it on my shou sugi ban furniture. Been using tung oil and tugn/danish oil for a bit of color.
I would like to try and keep the furniture as light colored as possible, I know that’s impossible with shou sugi ban, but I don’t want them looking ebony.
Anyone know of a good plain old wood oil? No color.
32 replies so far
View mrbob's profile
mrbob
182 posts in 590 days
#1 posted 04-21-2017 02:25 PM
How about Linseed Oil?
View Ron Aylor's profile
Ron Aylor
2631 posts in 669 days
#2 posted 04-21-2017 03:04 PM
+1 for boiled linseed oil
-- Ron in Lilburn, Georgia.  https://ronaylor.wordpress.com
RussellAP
#3 posted 04-21-2017 03:11 PM
Linseed oil tends to further darken. It must be some kind of chemical burn.
In fact, BLO has pretty much ruined anything I’ve put it on, which is why I’ve been using a lighter oil like Danish oil.
Ron Aylor
#4 posted 04-21-2017 03:14 PM
Try plain old mineral oil … I use a combination of of bee’s wax and mineral to clean my wooden planes; also an oil wicke of mineral oil to oil planes and saws … this has not “damaged” any wood to date.
I also use almond oil on my wooden fifes!
View Rich's profile (online now)
Rich
2959 posts in 611 days
#5 posted 04-21-2017 03:19 PM
I agree with Ron about the mineral oil. It’s about as clear as it gets.
View SignWave's profile
SignWave
440 posts in 3057 days
#6 posted 04-21-2017 03:53 PM
My understanding is that BLO has dryers.
For a non-coloring, non-drying oil, mineral oil comes to mind. You can buy it at any drug store.
-- Barry, http://BarrysWorkshop.com/
RussellAP
#7 posted 04-21-2017 04:45 PM
I might have some mineral oil lying around the shop.
As I remember, it was thick.
Can it be cut with mineral spirits?
What would be best to thin mineral oil?
View JayCee123's profile
JayCee123
200 posts in 786 days
#8 posted 04-21-2017 06:27 PM
Mineral oils not that thick, especially once you start working it into the wood. Mineral spirits or turpentine can be readily mix with mineral oil. Mineral oil is water clear, turps is slightly amber. If you want a slight bit of amber add a little paraffin oil, the stuff you use for rubbing out finishes. Respectfully, does it make that much difference to your project? Do you remove that much of the charred surface?
View Woodknack's profile
Woodknack
11761 posts in 2402 days
#9 posted 04-22-2017 03:58 AM
I don’t think you’ll be happy with mineral spirits, it looks good going on but a week later it’ll look like you didn’t do anything. I would suggest wax. Paraffin is probably the most neutral but you’ll have to melt it, possibly thin it. Beeswax might work for you.
Rich
#10 posted 04-22-2017 04:24 AM
I don t think you ll be happy with mineral spirits, it looks good going on but a week later it ll look like you didn t do anything. I would suggest wax. Paraffin is probably the most neutral but you ll have to melt it, possibly thin it. Beeswax might work for you.
- Rick M
I’m with you, but the OP was so specific about “plain oil,” that I skipped suggesting anything else.
Honestly, if you want a beautiful finish, go with Tried & True Original Wood Finish. It’s polymerized linseed oil and beeswax. The results are amazing.
Woodknack
#11 posted 04-22-2017 06:44 AM
I meant mineral oil. Brain fart.
View newwoodbutcher's profile
newwoodbutcher
742 posts in 2872 days
#12 posted 04-22-2017 08:04 AM
I don’t understand why there isn’t more discussion about Liberon furniture oil. I use it on black Walnut and Mahogany with fantastic results.
It’s not cheap but well worth it imop
-- Ken
View pontic's profile
pontic
591 posts in 630 days
#13 posted 04-22-2017 10:16 AM
Do like the Japanese do bleach it first then use BLO or BTO.
-- Illigitimii non carburundum sum
View Wildwood's profile
Wildwood
2322 posts in 2156 days
#14 posted 04-22-2017 11:58 AM
Only experience have with any wood burning are all those plywood hooch’s stayed in Vietnam. Think from the smell used kerosene as the final finish in-out side. Not sure who built, burnt, or finished inside those hooch’s.
From everything read about “SHOO-SUGI-BAN”, wood either unfinished or coated with natural oils. While Japanese used specific species of woods no word on type of oil other than natural oils.
If don’t want wood to look like ebony refine your burning, cleaning technique and leave unfinished or use a natural oil. Don’t actually know if Shoo-Sugi-Ban treated wood will darken with age when expose to UV rays. Natural oils can be drying normally used as wood finishes like Linseed, Tung, and Walnut oil. The only drying oil that affords any protection from water or moisture is Tung Oil if apply enough coats. There are other drying oils too just too many to list same is true of non-drying, or semi drying you could use.
Mineral oil (petroleum base) is a not drying oil finish I use for anything make for food safe knowing has to re-coated with use & time. Have no doubt would work on a Shoo-Sugi-Ban project in or outside as long as re-apply as needed.
-- Bill
Woodknack
#15 posted 04-24-2017 05:00 AM
Maybe you should try the newest fad, soap.
showing 1 through 15 of 32 replies
