Using my pneumatic stapler
Forum topic by EdsCustomWoodCrafts posted 04-21-2017 03:59 AM 482 views 0 times favorited 6 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
740 posts in 1217 days
04-21-2017 03:59 AM
Topic tags/keywords: pneumatic stapler 14 gauge garden mesh fence
I just wondering can I use my pneumatic stapler to secure some garden mesh wire to a 2×4 wooden frame ..
I’m wondering if the psi will be too strong to not tear through the mesh ( the mesh is 14 gauge)
Thanks…
I’m wondering if it’s just a question of lowering the psi output of the stapler
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
View Rrrandy's profile
Rrrandy
212 posts in 353 days
#1 posted 04-21-2017 05:20 AM
Experiment a little bit and see what happens.
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
View dhazelton's profile
dhazelton
2657 posts in 2170 days
#2 posted 04-21-2017 12:43 PM
Is it like chicken wire? A staple won’t rip through that. You need your air turned high enough to seat the staple anyway, probably around 90psi.
View Roger's profile
Roger
20898 posts in 2678 days
#3 posted 04-21-2017 01:04 PM
test pieces with different pressures will give you the answer
View verdesardog's profile
verdesardog
153 posts in 2485 days
#4 posted 04-22-2017 01:02 PM
adjust it so that it doesn’t drive the staples all the way in. I don’t know of a stapler that doesn’t’ have a depth adjustment.
-- .. heyoka ..
View EricTwice's profile
EricTwice
230 posts in 407 days
#5 posted 04-22-2017 01:17 PM
Yes you can, but you have to adjust the air pressure so you will not ruin your wire. You can also try shooting through a scrap of 1/4 inch ply to pad the mesh. (this will cut down on visibility so it’s a trade off, but do-able)
-- nice recovery, They should pay extra for that mistake, Eric E.
View tmasondarnell's profile
tmasondarnell
74 posts in 1663 days
#6 posted 04-22-2017 01:22 PM
You shouldn’t have a problem with the stapler—I have done this a few times.
The staples, however, will rust very quickly in the elements and you will get rust streaks down the lumber.
