Posted recently about buying an old Unisaw. The Owner sent me a video of the nickel test. No good?
Forum topic by jaminjames posted 04-21-2017 02:51 AM 2103 views 0 times favorited 10 replies Add to Favorites Watch
View jaminjames's profile
jaminjames
21 posts in 281 days
04-21-2017 02:51 AM
https://www.youtube.com/watch?v=6D07L4VemFU
To my untrained ear, the saw sounds to be running rough. Almost looks like there is some wobble in the blade as it starts up, but maybe thats just an artifact of the poor video quality. I do hear a pinging which reminds me of the sound my car made when it needed new wheel bearings. When he shuts the saw off the nickel falls, and the video cuts. I know it shouldn’t fall ever, so that can’t be a good sign.
Am I right that it sounded kinda rough? Is that something that replacing the arbor bearings would fix? I’m going to have Saw Center rebuild the arbor if I decide to buy.
I’m going to go look at it tomorrow. Would anyone be so kind as to give me a few pointers about signs to look for that would be a definite no go on this, and a few ways to test the integrity of the saw.
We’ve agreed on a price of $375 for the saw.
Thanks so much!
10 replies so far
View alittleoff's profile
alittleoff
520 posts in 1150 days
#1 posted 04-21-2017 03:17 AM
Theirs definitely something wrong with the saw. could be the Arbor bearings or bearings in the motor. Either ones are cheap to replace.
Gerald
View MrUnix's profile
MrUnix
6193 posts in 2073 days
#2 posted 04-21-2017 03:39 AM
Looks fine to me… heck, most of the machines I’ve bought didn’t run at all when purchased (even my Unisaw). The nickel test at this point is meaningless… you need to do it -after- you get it back into shape, not before!
As Scott mentioned in the other thread, you are getting a $200+ dollar fence with a Unisaw attached to it for just a bit more. Just check under the hood when you get there to see if you spot any obvious major damage, cracked or broken cast iron bits and any other problems. I doubt you will find any though… Worst case, even if there are, is you keep the fence and part out the saw to make your money back (and maybe even a little profit).
I bet you will find that with new motor and arbor bearings, a fresh set of belts and a good blade, that machine will be as smooth as butter. You can ship the arbor out like you mentioned, but it’s pretty trivial to replace those bearings yourself, and you don’t need any exotic special tools to do so. Your call… and your money :)
View BlasterStumps's profile (online now)
BlasterStumps
442 posts in 313 days
#3 posted 04-21-2017 03:54 AM
If a belt drive saw, possibly it has not had use for a period of time and the belt is where the vibration is coming from.
View Rick_M's profile
Rick_M
10829 posts in 2254 days
#4 posted 04-21-2017 04:05 AM
Sounds like a bearing to me. Could also just be crappy camera sound. Don’t worry about the nickel falling at the end. When the saw slows down they tend to shimmy a bit especially with an old belt.
-- http://thewoodknack.blogspot.com/
MrUnix
#5 posted 04-21-2017 04:09 AM
- Rick M
And single phase motors will shudder a bit anyway when the centrifugal switch closes and the start windings are brought back into circuit. Some more than others, and marginal bearings or belts will just make it more pronounced.
View Holbs's profile
Holbs
1770 posts in 1903 days
#6 posted 04-21-2017 04:14 AM
Would be a great purchase. Rehab time! To give an idea, my first run of new bearings and belts without the blade on my Unisaw:
View on YouTube
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View knotscott's profile (online now)
knotscott
7821 posts in 3249 days
#7 posted 04-21-2017 01:27 PM
I didn’t notice any problems or blade wobble. The blade is filthy and scorched, which may have given the illusion of blade wobble at slow speed to some. There’s a minor ringing coming from somewhere on the saw that could be as simple as a loose nut, washer, or screw somewhere, but it did not sound like a bearing issue to me. Bearings would be more of a constant squeal. I’d still be an enthusiastic buyer at that price.
View splintergroup's profile
splintergroup
1819 posts in 1096 days
#8 posted 04-21-2017 03:38 PM
That “dirty” blade makes determining things from the video difficult at best. Aside from the other things mentioned, I detect the blade rising slightly as the saw spins up, perhaps loose/worn worm screw on the height adjustment?
Anyway, impossible to confirm/deny based on the video but something to look at.
Rick_M
#9 posted 04-22-2017 03:47 AM
I’ve had blades that “ring,” very unpleasant to use.
View Carloz's profile
Carloz
1079 posts in 465 days
#10 posted 04-22-2017 11:12 AM
Know your buyer.
If I offered a Unisaw for $375 and the buyer would keep pestering me with weird requests to do a nickel tests etc I would just stop wasting time.
