Grizzly G09490X: How easy to move and roll?
Forum topic by PatrickIrish posted 04-21-2017 02:32 AM 946 views 0 times favorited 3 replies Add to Favorites Watch
View PatrickIrish's profile
PatrickIrish
101 posts in 2012 days
04-21-2017 02:32 AM
I’m picking up a grizzly g0490x jointer tomorrow. It has the built in mobile base.
How easy is it to roll this thing onto a truck lift gate? Not sure I’ll have another set of hands to help.
3 replies so far
View pmayer's profile
pmayer
1026 posts in 3032 days
#1 posted 04-21-2017 03:50 AM
It’s a very heavy machine, but I would think you could get it onto a lift gate by yourself. If you have to roll it across much outside surface I’d bring a couple sheets of plywood to provide a smooth surface. I brought mine home in the back of a Prius. I wouldn’t recommend that, however. Really bad idea, especially if it is your wife’s Prius. :)
View WoodES's profile
WoodES
96 posts in 1658 days
#2 posted 04-22-2017 04:45 AM
Not sure how yours is coming. Mine came in two pieces, bed in one crate and the base in the box. It had to be assembled before moving. My base has a 3 wheel configuration with the single wheel being the pivot to raise and lower the jointer. Ok for moving across the shop floor, but would be a pain to move on a drive of any roughness or grade.
The weight is in the beds and don’t pick the beds from the ends. Best to lift from the underside where the unit bolts to the base. If you can offload the beds to a pickup, you can move it from the pickup to the stand with minimal lifting.
Good luck…
View Kelly's profile
Kelly
2002 posts in 2911 days
#3 posted 04-22-2017 04:50 AM
Mine came in two pieces too. Here is my review of assembly and moving it: http://lumberjocks.com/reviews/6106
