Laying out a Big Star
Forum topic by Blakep posted 11-03-2010 04:31 AM 11693 views 1 time favorited 6 replies Add to Favorites Watch
View Blakep's profile
232 posts in 2732 days
11-03-2010 04:31 AM
So my uncle is a huge Dallas Cowboys fan. So big of a fan that one of his daughters is named Dallas and the other Landrey after Tom Landrey. My dad asked me today if I could make a Dallas Cowboys star thats about 3’ by 3’ out of wood and have a mirror put in it. My dad does metal work so he is going to had some ornamental iron to it. My problam is drawing a Cowboys star that large. How would you guys go about drawing this. I don’t know if i can draw a perfect star like that that’s small must less that large because all of its sides are perfect. If anyone has any ideas please let me know.
View davidroberts's profile
1027 posts in 3416 days
#1 posted 11-03-2010 04:55 AM
You only need to measure and draw one arm of the star (triangle) on say 1/8 inch hardboard, or posterboard, then just cut it out and trace around a pentagon. Or draw two triangles butted togetherto form one arm. The shorter triangle fits into the pentagon and touches a point in the exact center of the pentagon. It doesn’t matter where you start. Once you have outlined one arm with the two triangles, the rest fall into place.
-- Better woodworking through old hand tools.
View CaptainSkully's profile
1578 posts in 3488 days
#2 posted 11-03-2010 05:02 PM
I draw the circle to the correct size, then I make a mark at 12:00. Using a ruler, I estimate 1/5 of the way around and make a mark and measure. I transfer that measurement 4 more times around the circle. The last mark should land back at 12:00. If it’s short or long, adjust your measurement accordingly until you get five equal segments. Once you’ve got the marks, just connect the dots to make the star. If you have a divider, it’s easier to step it off.
-- You can't control the wind, but you can trim your sails
View swirt's profile
2604 posts in 2902 days
#3 posted 11-03-2010 05:28 PM
View Viktor's profile
462 posts in 3348 days
#4 posted 11-03-2010 06:01 PM
Animated version with compass and straightedge (second picture the from top)
View Mary Anne's profile
Mary Anne
1058 posts in 3138 days
#5 posted 11-03-2010 06:05 PM
Sounds like a cool project for a Cowboys fan. I look forward to seeing it finished.
I would use the same method as used for the tumbling block cutting boards. Set your fence at 30ยบ and make diamonds… only bigger. I am using this method for a star design in cedar for the ceiling in my hot tub room addition.
#6 posted 11-04-2010 07:14 PM
Thanks for all of the good tips. If I ever get caught up on my wifes list of things that she wants built then I am going to try the star and will post it.
