Supermax 19-38 Caster alternatives?
Forum topic by Timbersmith9 posted 04-19-2017 05:38 PM 1014 views 0 times favorited 6 replies Add to Favorites Watch
View Timbersmith9's profile
Timbersmith9
4 posts in 552 days
04-19-2017 05:38 PM
Got a Supermax 19-38 coming in and as wondering if there is a cheaper Serb of casters that will work.
View Kazooman's profile
Kazooman
1141 posts in 2093 days
#1 posted 04-19-2017 05:50 PM
I have the comparable Jet. Got a very nice set of casters at Lowes for much, much less than Jet wanted. Full swivel, locking, three inch wheels, and rated for much more load than the sander weighs.
Timbersmith9
4 posts in 552 days
#2 posted 04-19-2017 05:52 PM
Do you know if they use a bolt on the caster to attach to the stand?
- Kazooman
View Bill_Steele's profile
Bill_Steele
413 posts in 1873 days
#3 posted 04-20-2017 09:33 PM
They do use a stem type caster. Maybe you could use something like this and save alot of money?
I bought the casters offered with the sander and I think they are good.
You could probably find something inexpensive at Harbor Freight or maybe HD. Woodcraft sells casters—maybe these will work.
Whatever you get, I would suggest 4 casters that swivel and lock. It’s easier to maneuver when all 4 swivel. You will want to be able to lock the sander stand in place so it does not move around when you use it.
Kazooman
#4 posted 04-20-2017 10:20 PM
I am not certain about the Supermax, but like Bill stated, my Jet required stem type casters. I was initially concerned about the diameter of the shaft on my casters being a bit smaller than the holes in the ends of the legs. I made another trip to the Woodcraft store (an hour drive) and determined that the shafts on the expensive Jet casters were the same size. The sander is not a huge, heavy machine, and all sorts of aftermarket casters will work just fine.
View pauljuilleret's profile
pauljuilleret
103 posts in 1794 days
#5 posted 04-21-2017 11:07 AM
I also got a 19-38 about two months ago I also had issues as to the cost of the super max casters . What I did was go to my local Harbor fright and got some there they are heavy duty bolted on with the 1/2” threaded stud and if I recall they cost around $35.00 for the four. Note you will have to net your own 1/2-20 Nuts and washers as these are nutless.
View Lazyman's profile
Lazyman
2484 posts in 1528 days
#6 posted 04-21-2017 11:53 AM
These look like they are pretty reasonably priced.
