Can I proceed?
Forum topic by Pipertom posted 04-18-2017 10:58 PM 598 views 0 times favorited 9 replies Add to Favorites Watch
View Pipertom's profile
2 posts in 335 days
04-18-2017 10:58 PM
Topic tags/keywords: kiln drying air drying trim black walnut walnut
I have air-dried black walnut planks that were stickered and stored in my garage for the last seven years. Yesterday a local specialty woods yard planed them to ~ 3/4 thickness and the planer operator took a moisture reading which turned out to be 12% which was what he had predicted.
He suggested I let the wood dry for another year in the interior space where I’m going to use it (a bathroom where it will be used to trim out the windows, as a shelf over the counter backsplash and to trim out where the ceiling panels meet the beam.
My question is can I use it now or would it be better to find a place that will kiln dry it to the 7 – 8% that the plane man was recommending ?
9 replies so far
View DirtyMike's profile
637 posts in 834 days
#1 posted 04-18-2017 11:11 PM
Let her rip.
View JayCee123's profile
200 posts in 696 days
#2 posted 04-18-2017 11:46 PM
You’ve been air drying for 7 years, the moisture reading was 12%, that would indicate your local Relative Humidity is in the area of 64 – 70%. Have you been taking moisture content (MC) readings as you have been drying your stock ? That could have help you determine if your stock has reached equilibrium with your surrounding. If you have it kiln dried to 7 – 8% and then return it to your shop, without taking any measures to lower and control the relative humidity; the walnut is going to absorb the available moisture until it reaches equilibrium and eventually return to the 12% MC. Even with a finish applied, the walnut will continue to absorb moisture, at a slower rate, but given enough time the walnut will absorb moisture until it reaches equilibrium with its surroundings.
Not knowing the relative humidity in your area its difficult to say if your 12% reading is reflecting stock which has already reached equilibrium. Your indicated uses don’t seem to be so critical, and by following good WW practices you should be able to design for wood movement.
View dhazelton's profile
2719 posts in 2228 days
#3 posted 04-19-2017 12:07 AM
Use it. It’s going into a steamy environment. It doesn’t need to get any drier.
View jbay's profile
2163 posts in 831 days
#4 posted 04-19-2017 12:09 AM
Since it was just planed, I would give it a couple of weeks.
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View Bob5103's profile
86 posts in 765 days
#5 posted 04-19-2017 12:33 AM
Where do you live? I live in the Pacific NW and all of my wood is at 11-12%. Personally I would just carry on and “get er done”.
View mudflap4869's profile
1589 posts in 1391 days
#6 posted 04-19-2017 12:57 AM
The humidity in a steamy bathroom is always higher than it would be in a dry garage. Make allowances for swelling and build away.
-- Still trying to master kindling making
View Rich's profile
2467 posts in 521 days
#7 posted 04-19-2017 01:00 AM
+1 jbay
-- No matter how much you push the envelope, it'll still be stationery.
2 posts in 335 days
#8 posted 04-19-2017 01:19 AM
Man was that fast !
I live in upstate New York: hot and humid in the summer, cold and humid in winter. Indoor humidity is low from the effects of heating. I have to run a room humidifier to keep my instruments at a friendly level.
The reading the planer operator took yesterday was the first time MC was ever measured for this lumber.
Thanks to all LumberJocks who replied. I will be trimming my bathroom right soon !
View ArtMann's profile
900 posts in 748 days
#9 posted 04-19-2017 09:19 PM
Here is something to think about. Up until the 20th century, all lumber was air dried. Some of the most exquisite furniture I have ever seen is on display in Williamsburg, VA and was built in the 17th century. Obviously, that particular wood didn’t need kiln drying. The lumber doesn’t need to be 7% moisture. It needs to have the same moisture content as the environment in which it will be used.
