steel for thin parting tool
« back to Woodturning forum
Forum topic by kmetzger posted 04-18-2017 04:01 PM 1180 views 0 times favorited 14 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 1898 days
04-18-2017 04:01 PM
I’m looking for some good steel for making a thin parting tool. The tool I made and have been using needs sharpening constantly. Metals Depot doesn’t appear to sell 1/16” steel bar. Any suggestions?
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
14 replies so far
View jtriggs's profile
jtriggs
181 posts in 3897 days
#1 posted 04-18-2017 04:05 PM
I saw Capt. Eddie use a blade for a lawn edger to make a parting tool. Should be pretty tough stuff. Check out his vid on youtube.
https://www.youtube.com/watch?v=8Joo-cBzsjQ
-- Jon --Always remember, never live your life by a motto.
View Bob5103's profile
Bob5103
93 posts in 913 days
#2 posted 04-18-2017 04:06 PM
Check 0nlineMetals for their 01 steel. It’s pretty easy to work and heat treat/temper.
View bondogaposis's profile
bondogaposis
4889 posts in 2431 days
#3 posted 04-18-2017 04:11 PM
I made from a Dewalt rescue blade. Like this.
-- Bondo Gaposis
kmetzger
#4 posted 04-18-2017 04:21 PM
Thanks for both suggestions. Now I’m wondering if 3/32” wouldn’t be better than 1/16”. 5/64”?
View Woodknack's profile
Woodknack
12215 posts in 2460 days
#5 posted 04-18-2017 06:06 PM
View PanamaJack's profile
PanamaJack
4483 posts in 4157 days
#6 posted 04-18-2017 06:10 PM
I’ve used an old 1-1/2” thick Band Saw blade slapped two pieces of wood, one on either side, drilled and put two rivets to hold it together.
-- Carpe Lignum; Tornare Lignum (Seize the wood, to Turn the wood)
View papadan's profile
papadan
3584 posts in 3448 days
#7 posted 04-18-2017 06:19 PM
I used a hack saw blade. If you have a grinder to remove the teeth and shape the end be sure to keep it cool with a cup of water to dip it in so you don’t loose the temper. If no grinder you can use a Dremel to shape it.
View MrRon's profile
MrRon
4916 posts in 3323 days
#8 posted 04-18-2017 07:58 PM
These have a tyaper on the sides to allow clearance in the groove. https://www.mscdirect.com/browse/tn/Turning-Boring/Cut-Off-Blades-Holders/Cut-Off-Blades?navid=12105904
View OSU55's profile
OSU55
1779 posts in 2069 days
#9 posted 04-18-2017 09:43 PM
If you can go 1/8” here's a complete tool for $10
View BigYin's profile
BigYin
421 posts in 2496 days
#10 posted 04-18-2017 10:01 PM
power hacksaw blade
blunt ones free from metal shops.
-- ... Never Apologise For Being Right ...
View Arlin Eastman's profile
Arlin Eastman
4247 posts in 2641 days
#11 posted 04-18-2017 10:04 PM
I got some 12” planner blades from a few guys who were going to throw them away. They are very hard and just perfect for the job. You can ask a few guys here if they have any they are going to throw away.
-- It is always the right time, to do the right thing.
View SignWave's profile
SignWave
440 posts in 3115 days
#12 posted 04-18-2017 10:31 PM
https://www.amazon.com/uxcell-200mm-Rectangle-Boring-Cutter/dp/B00G9JOLP6/
I made one from a 2mm x 30mm x 200mm piece of M2 HSS. I ground out a tang and turned a handle, and viola! A stout and narrow parting tool for less than 8 bucks!
I would definitely recommend HSS for turning tools. Much easier to freshen the edge on the grinder than any of the heat treated steels.
-- Barry, http://BarrysWorkshop.com/
View TonyArru's profile
TonyArru
32 posts in 2294 days
#13 posted 04-27-2017 01:07 PM
My wood turning teacher has made his own thin parting tool out of an old rail road tie hacksaw blade. Apparently you can find these in many places including flee markets, antique stores and even along the railroad tracks. When ever a blade got dull the workers would change the blade and toss the old one on the ground, and there it stayed. But the steel is supposed to be really good and strong. I assumed from his story that he was talking about, railroad workers from 50+ years ago….
That being said, I have used a sharpened butter knife to get the job done as well…just make sure its solid steel and not the two part plastic handle kind….
View Woody2016's profile
Woody2016
7 posts in 482 days
#14 posted 04-27-2017 05:58 PM
I use old Sawzall blades. They work great just grind off teeth a a and throw a handle on it. Parting tools AR not expensive to buy but I am cheep and will make tools before buying them.
