Request: Help Locating a Jointer Table Alignment *.pdf
Forum topic by go4tech posted 04-18-2017 01:01 PM 375 views 0 times favorited 3 replies Add to Favorites Watch
View go4tech's profile
8 posts in 961 days
04-18-2017 01:01 PM
Topic tags/keywords: jointer question resource
Have seen in the past a single page outline drawing showing “common” jointer table alignment issues with the associated results along with an explanation of the condition.
As the flying fickle finger of fate has it, when one wants to have a copy, not to be found. Been looking for two days.
Can some kind sole please post, or post the link, of this one page *.pdf.
Thanks in advance!
3 replies so far
View Aj2's profile
1310 posts in 1734 days
#1 posted 04-18-2017 02:01 PM
Are you looking for info on a particular jointer? Vintage machinery probably has one in Delta or powermatic jointer manuels.
I’m a self proclaimed expert in setting up a jointer.
Can I help?
-- Aj
View pintodeluxe's profile
5596 posts in 2749 days
#2 posted 04-18-2017 02:47 PM
Here’s one.
8 posts in 961 days
#3 posted 04-18-2017 05:16 PM
Thank you so much for the responses.
What is being sought is a single page “illustration ” of common jointer issues (such as tipped in feed table, high out feed table, etc.) with explanation of the amount of “error or offset” in the particular table and line art drawing of the resultant work piece.
Believe that it was/is on Wood Central. Can not find it when wanted. It is a very good one page reference of for this amount of error, this is the type of result one should expect. It was a black and white line drawing with explanation included.
Hope this is positive and on-going. Thank you.
