Removing Watco wipe on poly
Forum topic by Peace posted 04-17-2017 10:25 PM 492 views 0 times favorited 2 replies Add to Favorites Watch
View Peace's profile
Peace
13 posts in 607 days
04-17-2017 10:25 PM
Topic tags/keywords: sanding
I have plywood tables on which I used Watco Natural Danish oil. Over that I used 2 coats of Watco wipe on poly. The Danish finish job has proved to be poor, and I would like to remove it. Can I first remove the poly by some means other than sanding before I sand off the Danish?
2 replies so far
View Rich's profile
Rich
2998 posts in 616 days
#1 posted 04-17-2017 11:06 PM
You could use a stripper, but that’s messy. Wipe on poly doesn’t build that much, especially just 2 coats. I’d sand it.
View JayCee123's profile
JayCee123
200 posts in 791 days
#2 posted 04-18-2017 12:12 AM
You have a couple problems here. Poly is a bear to remove and if you remove sanding from your options that leaves a chemical stripper or scraping. Chemical removal is messy and your dealing with potentially dangerous chemicals. Scraping involves labor and technique, but at least you can move at your own speed. The scrapers are a cheap investment. Once the poly topcoat is removed you will have an oil which has penetrated below the surface. You probably wouldn’t be able to remove the oil. You’ll need to color the surface to hide the oil discoloration or blend with a tinted oil. After you’ve blended lay on a coat of de-waxed shellac, then proceed with a clear coat.
Re consider sanding, as RichTaylor indicated. As a second, I would use a card scraper, not a paint scraper. You’ll have better control and less cuts into the plywood surface. Stay away from strippers unless you have some experience using them.
