| Forum topic by lumbermaker | posted 662 days ago | 3594 views | 0 times favorited | 13 replies | ![]() |
662 days ago |
Topic tags/keywords: question lumber Hello, forum. I have a couple of thousand board feet of native lumber. It has been stripped and stacked in a barn for about four years and I also have use of a dehumidifier kiln. I’ve taken my time when drying the lumber and for the most part haven’t run into any major problems. My question is after the lumber is dry how do I put a straight edge on it? I want to know some of your thoughts on the most efficient way to accomplish this task. I’ve heard to chalk line it and run it through a table saw, but if I can make a simple profit I may do this for a supplemental income and don’t want to even think of running several thousand boardfeet through a table saw every year. I could have the bandsaw come back and straight edge them, at an additional cost, or I could manufacture some sort of rip saw. I read oscorner’s blog on the “Woodmaster” 4-in-1 planer and wonder if he ever got around to trying the rip saw attachment. Does it work well? Does it pull the lumber through straight like a commercial rip saw or does the lumber curve? I guess I could try it out, but I don’t want the headache if it’s not going to meet my needs. I have access to a jointer, but haven’t bought a planer yet. My goal is to manufacture quality native lumber to sell to local craftsmen and hobbiest. What are your thoughts? -- A straighter board I've never seen, than the one last night in my dream. |
662 days ago |
That much lumber I would find a local mill to do it. I have one that will surface two sides and straight line Something to think about. -- Gary, East TX -- The longest journey begins with a single step. |
662 days ago |
Thanks for the speedy reply. That would probably make the most sense. I have a mill that would work and it’s less than 20 miles away, I’ll give them a call. I just started processing some of the wood I ran through the kiln and noticed that I lost an eight of an inch due to shrinkage. I was wondering what thickness would be acceptable to woodworkers after I’ve finished joining and planning? I started out at a true 1 inch thickness. No big deal on this first batch as I can use it myself and figured there would be a learning curve. It also has occurred to me that next time I may want to shorten the length of the lumber prior to stacking so I could move it myself with a lot less effort. What would you say is the most desirable length you use? -- A straighter board I've never seen, than the one last night in my dream. |
662 days ago |
With that much lumber I agree with Gary. If you had a smaller amount then here are a couple methods that you could use: (1) snap a chalk line and use a circular saw to rough cut it Normally for rough lumber you would aim for a dry thickness of about 1 1/8” to allow for surface jointing and planing to finished size. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
662 days ago |
Six foot would probably be the longest piece anyone would use for furniture, but there are exceptions. 3/4 inch is about the standard for thickness. Hope this helps. -- Gary, East TX -- The longest journey begins with a single step. |
662 days ago |
If you decide to put a straight-edge on it yourself, Festool is the original, but lots of other people now are manufacturing plunge saws with rails. As long as you can set up the rail without twist, it’s a great way to put a straight edge on just about anything. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
661 days ago |
I’ve read a few articles/blogs by fellows that set up their own rail system and I’ve heard of the plywood sled for the table saw, so I guess it’s just a matter of making up my mind of whether I want to do this job myself or get it done at the mill. (Buying my own edger is only going to happen when the Wife sells the house and moves into the barn-so never.) The only thing (besides cost) that might sway me is whether the mill is timely in doing my job or if I have to wait a considerable time. It looks like the only way to settle this is to run a batch through them and see what happens. Thanks again for all of your input and if you run across any articles/blogs on the subject of processing trees to useable lumber I’d appreciate a line. Mike Keller -- A straighter board I've never seen, than the one last night in my dream. |
658 days ago |
I do almost everything from rough lumber (usually “rough” as in tree form…....”). I thickness plane first to desired thickness and then the pieces with a fairly straightedge (eyeball method) go thru the jointer. Questionable ones go to the table saw with an extra long straight fence and are methodically “straightened” by cutting one side and then the other. With a bit of practice, it goes fairly well. If the piece is way out of “straight”, most times I will cut it in half, or in the middle of the biggest bend, and reduce the amount of material I need to remove to get a straight edge on it. A lot of people call me crazy, or that my methods don’t work…... but I’ve salvaged a lot of material that mills and yards were gonna throw away because of warping and twisting issues. |
656 days ago |
Okay, I’ve got a Woodmaster 712 that includes a gang saw. You will not be able to straight line rip with it if the lumber has quite a curve to it. In fact when I gang rip I have to hold the wood tight to the guide or it will wander. The gang saw is more to cut your stock to exactly the same width for when you want to run it through the molding knives. -- Jim |
630 days ago |
Jim…I’d be very interested in seeing the pictures of your guides. I have a Woodmaster 718, and the gang rip saw works great…once you have a straight egde. Your straight edge guide seems like the ticket for running 16’ molding blanks. Thanks! Pat |
630 days ago |
OK Pat, remember you asked for it. My jig isn’t fancy, but it works great. -- Jim |
630 days ago |
I too agree withGary. I’d have the mill do it. If I was doing it myself, I’d joint one edge first then the 90o surface. Then plane the paralell side and then use the table saw for the last edge. -- Bruce from Central New York |
630 days ago |
I have 1500 board feet of white pine in the loft of my workshop. most boards are 4/4 and 8’ long. they were cut on a Woodmaster and many do not have straight edges. I scribe a straight line along the edge and cut along it using my bandsaw. With a wide blade, it is remarkable just how straight a line I can cut. I then finish it up on the table saw or jointer. It’s a simple solution – but it works for me. Now if only the snow will melt U.P. there. -- "Heaven is North of the Bridge" |
630 days ago |
I would go with a 1 1/8 inch thickness and let a mill do the straight ripping. I buy most of my lumber completely rough and do the straight line ripping and planing myself. If you are reselling you might want to consider seeing if there is a market for the wood in rough form. -- Those that say it can't be done should not interrupt those who are doing it. |
| Forum | Topics |
Woodworking Skill Share
2937 |
3968 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
