threading a wood face plate
« back to Woodturning forum
Forum topic by Karda posted 04-16-2017 11:35 PM 912 views 0 times favorited 26 replies Add to Favorites Watch
View Karda's profile
Karda
1222 posts in 670 days
04-16-2017 11:35 PM
Hi, I have seen mentioned that you can thread wood to use for your face plate with a bolt the size of the lathe. I have not been able to find any information on how to do that has any body done that and how do you do it. I have threaded with 1/4 in and that was hard I can imagine that 1 inch would be a lot harder if not done right thanks Mike
26 replies so far
View woodcox's profile
woodcox
2094 posts in 2129 days
#1 posted 04-17-2017 12:06 AM
You can buy taps to match the thread pitch for you lathe. Drill the recommended size hole, thread it with the tap, then mount it up and turn it true. A great way to make quick custom faceplates. Most ww stores have them and the correct drill bits.
-- "My god has more wood than your god" ... G. Carlin.
View hairy's profile
hairy
2750 posts in 3649 days
#2 posted 04-17-2017 12:08 AM
Drill a 7/8” hole for 1”.Mount the workpiece in the headstock and lock it.Start the tap by hand,bring up the tailstock for light pressure to keep it aligned. Turn the tap, then turn the tailstock in. Repeat. I put thin CA glue in the threads and retap AFTER the glue is dry.
-- My reality check bounced...
woodcox
#3 posted 04-17-2017 12:12 AM
Great idea with the glue hairy, Ima try it!
Karda
#4 posted 04-17-2017 12:47 AM
no wood working stores in my area just lowes and such, I can get a 1×8 bolt tap the bolt tap will not have a divit in the end for the tail stock to press into what can I do there
Karda
#5 posted 04-17-2017 12:49 AM
View Woodknack's profile
Woodknack
12331 posts in 2497 days
#6 posted 04-17-2017 12:51 AM
You can get a tap for about $10, worth it.
View Michael McKenzie's profile
Michael McKenzie
64 posts in 556 days
#7 posted 04-17-2017 12:55 AM
The CA glue trick will work. Best stabilizer out there BUT be sure to wear respirator when working with it on lathe and especially sanding it. Fumes are one thing , solid particles of that dried CA is quite another and it will BURN your eyes as well just the fumes and the dust. So you get it twice when working with it.
-- ~ Ancora imparo! ~
View waho6o9's profile
waho6o9
8356 posts in 2693 days
#8 posted 04-17-2017 01:08 AM
Woodknack
#9 posted 04-17-2017 02:10 AM
View papadan's profile
papadan
3584 posts in 3485 days
#10 posted 04-17-2017 02:22 AM
Karda, get a bolt the size you need and use a dremel or a file and cut a couple slots into the bolt so that you have a flat side cutting into the wood when you thread the bolt into it. Crude drawing
MrUnix
6887 posts in 2315 days
#11 posted 04-17-2017 02:29 AM
Just get a tap – it will cost about the same as a 1” bolt and work a lot better. Don’t make things more difficult than needed :)
PS: Cheapest 1”-8tpi bolt I could find over at Fastenal was around $5. I don’t think you will find them at the BORG, so you will need to go to a supplier like Fastenal, Graingers, McMaster Carr, etc…
View JollyGreen67's profile
JollyGreen67
1676 posts in 2879 days
#12 posted 04-17-2017 02:59 AM
That’s the only thing we used when I started turning in the 6th grade: 1-1/4 tap.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
View Jacksdad's profile
Jacksdad
200 posts in 541 days
#13 posted 04-17-2017 03:19 AM
Woodcraft sells the tap for 1 inch and 1 1/4 headstock’s.
papadan
#14 posted 04-17-2017 05:47 AM
I certainly understand that a real tap will work faster and easier, but the OP asked about tapping wood with a bolt. That’s the question I answered. If I knew where he lived I would send him a homemade tap that I made 20 years ago and still works perfect. I have always been an industrial mechanic and have all kinds of big bolts.
Karda
#15 posted 04-17-2017 07:08 AM
Hi, I can get a bolt and I can get a bold tap, My concern with the tap is that there is no way that I can see for it to pivot on the tailstock because it doesn’t have a pit on the end for the drive to pivot in so as you turn the tap the drive center is going to wander. Just like drilling metal with out firs with a punch creating a dimple This can be done with a bolt unless the p tap is soft enough to drill in a dimple. Thanks papadan for the offer
