Need input
Forum topic by kenthemadcarpenter posted 04-16-2017 08:33 PM 775 views 0 times favorited 10 replies Add to Favorites Watch
View kenthemadcarpenter's profile
kenthemadcarpenter
124 posts in 1209 days
04-16-2017 08:33 PM
Topic tags/keywords: question planer
So I need some honest reviews, I am in the market for an electric hand plane, My budget is around two hundred dollars. The reality is it will probably not get used very often. I have two upcoming projects whereI will need to use it. Suggestion from actual users.
10 replies so far
117232 posts in 3718 days
#1 posted 04-16-2017 08:39 PM
Hi Kent
It depends on what size you want but for my use, this Bosch does the trick.
https://www.amazon.com/Bosch-1594K-6-5-4-Inch-Planer/dp/B000067S14
View JayCee123's profile
JayCee123
200 posts in 906 days
#2 posted 04-16-2017 08:48 PM
Yes the Bosch !
Great depth of cut control.
Wide enough plane blade for my use.
Great for trimming out doors.
View BurlyBob's profile
BurlyBob
5911 posts in 2407 days
#3 posted 04-16-2017 08:50 PM
Not knowing your project makes it difficult to offer good advice. I bought a Makita about 10 years ago. I’ve used it may 6 times. Basically I feel like I wasted my money. It’s a difficult tool to use and the results were less than sterling. If your just wanting to hog away a lot of material with out concern for a quality finish it’ll get the job done. It’s definitely not a finish tool by any means.
View Texcaster's profile
Texcaster
1287 posts in 1815 days
#4 posted 04-16-2017 09:31 PM
Power planers are mainly a site tool for fitting doors and scribing cabinets. They can be put to good use in the shed for bulk waste removal. Mine is used to rough dress slabs and for carving. Most people overlook the “vapor cut”. I wore out a Mikita and have been using a Hitachi for the last decade.
Dressing a cupped benchtop.
http://lumberjocks.com/Texcaster/blog/53473
-- Mama calls me Texcaster but my real name is Mr. Earl.
View mahdee's profile (online now)
mahdee
3990 posts in 1909 days
#5 posted 04-16-2017 10:33 PM
I bought a Makita one for a few hundred box and the HF one for $29 has outlasted it 5X over.
-- earthartandfoods.com
View MerylL's profile
MerylL
70 posts in 1512 days
#6 posted 04-17-2017 03:31 AM
I bought a Porter Cable at Amazon. I really like it. It is not for fine work… I can’t see how any of these are. What I use mine for is 2 things: Dressing windows to fit as I restore them (106 y-o). They were never fitted at time of instalaltion from what I can tell. Second is to remove lead-based paint from said windows AND doors in my house. I’ve stripped a dozen 2-panel doors, and maybe 15 or more windows. I have another 18 to go! In fact, I just removed one today. But I digress… the PC will adjust in 1/64 increments. Mine was co-planar, and worked like it should right out of the box. The first set of blades lasted forever, even with the lead paint they were eating off. The dust bag is, like any, more an inconvenience. I use a shop vac on it for most of my work. Gotta be careful, though, that the weight of the hose doesn’t tilt you into cutting a tilted cut. As i recall it was well under $200.
View waho6o9's profile
waho6o9
8405 posts in 2718 days
#7 posted 04-17-2017 03:44 AM
Porter Cable here as well:
I use it when hand planes take too long.
waho6o9
#8 posted 04-17-2017 03:50 AM
http://www.harborfreight.com/catalogsearch/result?q=electric+planer
MOST LIKED NEGATIVE REVIEW
REPLACEMENT BELT UNAVAILABLE FOR 3-1/4” ELECTRIC PLANER
Tool worked fine until belt broke. Unable to find replacement. I purchased a 24” x 1.75 self sealing inner tube, cut to size and it works find. Although planer grooved it did not come off. Cheap fix and you will have plenty belts should this one break! Moe
http://www.harborfreight.com/3-1-4-quarter-inch-electric-planer-91062.html
Seems well received with the caveat being there’s no belt available for replacements.
If you’re not going to use it much maybe this can save you some money, hopefully without
the aggravation.
View josephf's profile
josephf
202 posts in 2238 days
#9 posted 04-17-2017 03:54 AM
i have several . I have a shortbed inexpensive single blade bosch in the truck .A longer bed metabo and 4” wide makita . All of them are older models . I would probable get a cordless next time .
That said for hogging material a more powerful machine is important . If your trying to flatten something rather then hog a section out a long bed is helpful . I would not consider one that did not allow switching direction/or side the chips went out . Also it real important that I can hook a vac to mine . I do not need to spend my time sweeping up chips .
How do you expect to use it ?
View Kelly's profile
Kelly
2074 posts in 3086 days
#10 posted 04-18-2017 01:25 AM
I have a Porter Cable 9125 3-1/4-Inch. I love it and hate it. The problem I have with it is, the hook at the top of the handle makes it very uncomfortable to use for long periods. Other than that, it’s removed a lot of material over the years and just keeps going and going.
