Festool Domino Patent
« back to Coffee Lounge forum
Forum topic by Nostradamit posted 04-16-2017 08:06 PM 4898 views 0 times favorited 15 replies Add to Favorites Watch
View Nostradamit's profile
Nostradamit
41 posts in 1072 days
04-16-2017 08:06 PM
Does anyone know when the Festool Domino Patent will run out so some other tool manufacturer can make one and make it more affordable. Nothing against Festool who make great tools, it’s just a little to expensive for my budget.
15 replies so far
View Woodknack's profile
Woodknack
12455 posts in 2615 days
#1 posted 04-17-2017 03:06 AM
Russian guy on YouTube came up with a diy version, he has plans for it. Can’t remember his name but shouldn’t be hard to find with Google.
View papadan's profile
papadan
3584 posts in 3603 days
#2 posted 04-17-2017 06:01 AM
Why not just use 2 dowels beside each other. Just as strong and a hell of a lot cheaper than Dominos
View pontic's profile
pontic
663 posts in 843 days
#3 posted 04-17-2017 12:48 PM
I thought there was a test done by the JFW some time ago that showed that double #20 biscuits were just as strong as just about any other type of wood to wood joint.
I could be wrong but I think that is what they found.
-- Illigitimii non carburundum sum
View rejo55's profile
rejo55
190 posts in 2477 days
#4 posted 04-17-2017 01:52 PM
You might check out mirock. He’s a Ukrainian Lumberjock and has posted some miraculous work. Seems as if he could single-handedly put Festool out of business. I haven’t seen the domino tool, but he has come up with some awesome Festool copies. I try to never miss his posts.
Have a good’un
Joe
Rejo55, East Texas
-- rejo55, East Texas
View DrDirt's profile
DrDirt
4526 posts in 3977 days
#5 posted 04-17-2017 03:07 PM
I think Stumpy nubs also built a DIY domino from a Harbor Freight trim router
http://www.stumpynubs.com/hand-held-mortiser.html
As to your actual question… in general a patent is 7 years. So getting close.
But I think as you make ‘improvements’.. e.g. now the XL version. You can ‘renew’ your claims and extend your patent protections.
I suspect that there is a pretty limited (Niche) market, otherwise there would be another entrant, that is “Officially/Legally different enough to get to market”
Like the Bosch REaxx saw, competing with Saw Stop.
But I don’t think there are thousands of folks lining up to get one, so it isn’t worth their time.
Woodknack
#6 posted 04-17-2017 04:40 PM
View BuffaloBrewer's profile
BuffaloBrewer
61 posts in 1053 days
#7 posted 04-17-2017 08:52 PM
I believe it’s 20 years.
The term of the patent shall be generally 20 years from the date on which the application for the patent was filed in the United States or, if the application contains a specific reference to an earlier filed application under 35 U.S.C. 120, 121 or 365©, from the date of the earliest such application was filed, and subject to the payment of maintenance fees as provided by law.
https://www.uspto.gov/patents-getting-started/general-information-concerning-patents
DrDirt
#8 posted 04-17-2017 11:27 PM
I believe it s 20 years.
- BuffaloBrewer
Agree –
View ChuckV's profile
ChuckV
3183 posts in 3762 days
#9 posted 04-18-2017 12:24 AM
I did not read through it, but here is a similar thread from 2012:
http://lumberjocks.com/topics/34799
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View Carloz's profile
Carloz
1147 posts in 826 days
#10 posted 02-01-2018 12:49 PM
Jut saw it at Rockler:
Carloz
#11 posted 02-01-2018 01:03 PM
.. in general a patent is 7 years. ...
- DrDirt
So how come Sawstop won a patent infringement lawsuit against Bosch 17 years after the filing?
View bigblockyeti's profile
bigblockyeti
5310 posts in 1955 days
#12 posted 02-01-2018 01:48 PM
I’m thinking its closer to 20 years as well, the best example I can think of is the Fein multimaster. They’ve been around for quite some time and only in the last few years has nearly every major power tool manufacturer come out with an oscillating tool where no one but Fein had them available before.
View drrossw's profile
drrossw
1 post in 302 days
#13 posted 10-27-2018 01:53 PM
I believe there are many woodworkers that would buy one if the price came down significantly. I know I would. Remember when Fein had the only multitool. Now everybody makes them.
View Andybb's profile
Andybb
1599 posts in 838 days
#14 posted 10-28-2018 01:16 AM
- Carloz
The beadlock is ok. I have one, but it’s not a domino. Just as strong but nowhere near as convenient. The stumpy nubs one was fine but it looked like too much work to build. My stuff never comes out as nice as his. Someday there will be a Delta or even a Harbor Freight version if I live that long. Once I figured out how to do m&t joints its faster than setting up the beadlock unless it’s just a repetitive 90 degree joint.
-- Andy - Seattle USA
View Dustin's profile
Dustin
611 posts in 975 days
#15 posted 10-29-2018 01:06 PM
- Carloz
The beadlock is ok. I have one, but it s not a domino. Just as strong but nowhere near as convenient. The stumpy nubs one was fine but it looked like too much work to build. My stuff never comes out as nice as his. Someday there will be a Delta or even a Harbor Freight version if I live that long. Once I figured out how to do m&t joints its faster than setting up the beadlock unless it s just a repetitive 90 degree joint.
- Andybb
I’ve switched to using a mortising jig for my joinery (smallish tables, usually 3/4” to 7/8” thick aprons and 3/8” floating tenons). It works, is repeatable, and was super cheap to build. That said, I don’t do very many projects, but if I did, I think I’d find a way to bite the bullet on the Domino price tag.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
